Like Tree1Likes
Xray T3 2012
Old 06-15-2012, 02:37 PM
  #2836
Fred Hubbard's Avatar
Originally Posted by UrabusDenis
Does the front Yokomo belt fit our car?
No the rear belt fits.
Fred Hubbard is offline
Old 06-15-2012, 02:41 PM
  #2837
The hot bodies cyclone front belt 68703 171t fits tho
Bryan D is offline
Old 06-15-2012, 07:13 PM
  #2838
Dusttt's Avatar
Trader Rating: 144 (100%+)
Anyone running the LRP radical heatsink on their car? Just got one and I dont see it fitting.
Dusttt is offline
Old 06-15-2012, 07:41 PM
  #2839
NR
NR's Avatar
Trader Rating: 52 (100%+)
I had no problems with it fitting, although I have known some people to grind the top deck a bit, but I didn't need to do that.
It was a while ago and I can't remember which way I ran it. I think it was at the front of the motor
Nathan
NR is offline
Old 06-15-2012, 08:05 PM
  #2840
FK05 lover's Avatar
Trader Rating: 147 (99%+)
Originally Posted by FK05 lover
Tried an XR3'12 at our test facility (street), seemed sharper than T3'12 with similar set up,
will give it a go at the track tonight
Exotek XR3 deck is money well spent (& top deck too)....
FK05 lover is offline
Old 06-15-2012, 08:11 PM
  #2841
Dusttt's Avatar
Are you running shims under the rear blocks?
Dusttt is offline
Old 06-16-2012, 04:15 AM
  #2842
Default new 1.6 topdeck
Hi,
Appart from adding more flex to the car, how does the new thinner topdeck effect the handling?
Is it more noticable in the entry steering or in the middle part of the corner or perhaps is more noticable in rear grip, any thoughts?
Matt W is offline
Old 06-16-2012, 04:27 AM
  #2843
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Matt W
Hi,
It gives middle, which may cause inconsistency.
defcone is offline
Old 06-16-2012, 05:21 AM
  #2844
What do you think guys....should i use 2mm plate or 2.5mm for the race tomorrow? Track is medium grip and temperature forecast is 30degrees celsius for tomorrow.
Thank you in advance!
Likeslowww is offline
Old 06-16-2012, 07:07 AM
  #2845
artwork's Avatar
Trader Rating: 88 (100%+)
If I was running outside on medium grip asphalt I would be running the 2.0 chassis and 1.6 top deck.
artwork is offline
Old 06-16-2012, 08:35 AM
  #2846
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
I like the thinner chassis outdoors on asphalt especially with low to med grip.
Then I would adjust flex with the topdeck.
rdlkgliders is offline
Old 06-16-2012, 01:04 PM
  #2847
Potoczak's Avatar
Trader Rating: 120 (100%+)
Is the 2.0mm chassis and 1.6mm top deck available anywhere yet??
Potoczak is offline
Old 06-16-2012, 02:39 PM
  #2848
NolanP's Avatar
Superior had em at one point. I either bought the last or one of the last.
NolanP is offline
Old 06-16-2012, 10:53 PM
  #2849
Dusttt's Avatar
Dusttt is offline
Old 06-16-2012, 11:40 PM
  #2850
Default Exotek
I am not running any shims . With none it's pretty close to mid roll centers and outdoors I tend to stay with that most the time
AARON YOUNG is offline
