Like Tree1Likes
Xray T3 2012
Old 06-03-2012, 04:44 PM
  #2716
ByteStream's Avatar
Originally Posted by or8ital
This is how close I can get with the stock link as short as possible. looks like I will need to find a shorter turnbuckle.
Cut it with a dremel or use the ones for the camber link if you have spares.
ByteStream is offline
Old 06-03-2012, 05:14 PM
  #2717
Trader Rating: 38 (100%+)
Put an associated link on there which is now really bothering me. Ha ha.
or8ital is offline
Old 06-03-2012, 06:15 PM
  #2718
smilekt's Avatar
Not sure where you race as you don't have a location listed. Windy day here in the Midwest yesterday. We were all having the same trouble and concluded it was just the wind doing it. We all were having to trim out radios to go straight on the straightaway.
Could be tweak or some other kind of imbalance. What kind of servo? Are you running a cap on your receiver? Maybe the servo is losing power (strength) at full throttle?
Originally Posted by defcone
Might be your droop, place your car on a flat surface and lift the center of the rear end and look to see if your wheels lift off the surface the same time. Are you using a servo saver? Try swapping that for a servo horn see if that fixes the problem.
Originally Posted by yokemad
You should check
Tweak
Servo saver
Bearings
Shocks (if all4 still have same amount of rebound)
thanks for help .. i will looking for those advise above .. thank again
smilekt is offline
Old 06-03-2012, 06:23 PM
  #2719
Meradin's Avatar
Trader Rating: 19 (100%+)
I must have had a short one in my bin, I don't remember having to cut one but I didn't use the stock one if that helps. Just cut it at both ends and you will be fine.
Meradin is offline
Old 06-04-2012, 12:05 AM
  #2720
Default steering distance
even with spektrum dx3r endpoints on 150 max left and right steering arms are still a few mm away from hubs any way of getting more steering ? on my t3 2010 had to turn down endpoints has steering was touching front hubs
moggy12 is offline
Old 06-04-2012, 01:08 AM
  #2721
roger999's Avatar
You need to get 32 mm turnbuckle, but remember not alu one just a steel. My alu was bent after 2 races. I dont know why Xray gives too long turnbuckle???
roger999 is offline
Old 06-04-2012, 03:29 AM
  #2722
You have several possibilities :
1 : you use a hole on the servo-saver that is higher (so more distance between the center of the servo-saver and the used hole. Be sure to set your servo-saver with the hole at the vertical of the center when your servo is on his neutral point.
2 : you add some shims here, but you change the ackermann
3 : you make an hole in the main steering platic part that is nearer the center of rotation. On this piture, this hole is at the same distance that what was set on the "L" plastic part of the T3 '11 :
If you use this hole (and you reverse both right and left plastic parts so keeping the same length of turnbuckle), you get more steering with the same servo travel.
Hope it can help you (even if it's strange that you can't get enough steering with the TX at full end point)
FFred is offline
Old 06-04-2012, 03:55 AM
  #2723
You sure your dual rate isn't turned down. Same radio here. No issues.
or8ital is offline
Old 06-04-2012, 04:08 AM
  #2724
Can someone explain the shim behind the shock setup?
- what does it do?
- which box on the setup sheet indicates it?
- I assume the shims should be the same both at the top and bottom of the shocks?
I built mine with no shims. Seemed to work.
Anyone?
or8ital is offline
Old 06-04-2012, 04:43 AM
  #2725
thanks guys for info i forgot i turned down dual rate to 60 % put back to 70% all fine now what is best steering rate of the dx3r for the xray t3 2012 to race indoor on carpet ?
moggy12 is offline
Old 06-04-2012, 04:47 AM
  #2726
Well it's relative based on your end point adjustments and what the dual rate was at when you set it up. You may want to put your dual rate back to 100 and then reset your endpoints. From there I like to keep mine at around 90 percent for the track I race at.
or8ital is offline
Old 06-04-2012, 05:49 AM
  #2727
MikeXray's Avatar
Trader Rating: 73 (100%+)
- what does it do?
- what does it do?
Changes the resistance of the shock, kinda like having more holes in the tower with lesser increments.
The one labeled "Shim under shock"
No, usually people will shim the top first, I have seen some setups where people shimmed the entire shock away from the arm.
The whole idea seems like it shouldn't make a "noticable" change, but oddly it does, usually its used to mellow out the car.
MikeXray is offline
Old 06-04-2012, 05:58 AM
  #2728
Originally Posted by MikeXray
- what does it do?
THANK YOU!!
So what is a good starting setting top/bottom front and rear?
or8ital is offline
Old 06-04-2012, 06:04 AM
  #2729
MikeXray's Avatar
THANK YOU!!
2mm up top with 0 on the bottom.
MikeXray is offline
Old 06-04-2012, 09:39 AM
  #2730
M-Technic's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Mera'din
I had a similar question over in the '11 thread. What I was told is that 90 degrees with the arm and chasis isn't what you are looking for. Rather, you want 90 degrees between the link and the arm. The arc the arm travels is what you need to be concerned with.
The kit manual says 90* to the chassis, which is what I am running, but I had to use a LOT of subtrim to get my servo saver vertical, and my EPA's left and right are about 20% different.
M-Technic is offline
