Like Tree1Likes
Xray T3 2012
Old 05-22-2012, 06:58 AM
  #2536
nashrcracer's Avatar
Originally Posted by Team_Krusty
I always run 2 deg camber and dont remember having any problems. Try swapping back to the 52mm and just check for any binding. I dont know if this will fix your problem but that wear seems unusual.
Simon
I had a conversation back in 2010 at the Halloween classic about my 2011 I had just put together with a xray pro driver. He couldn't understand why they ship the car with 52 rears. He pretty much told me the only way it runs at all without binding is with 50mm rears EVEN if you did only use 1.5 degree camber. That and check your swaybars some might not be completely flat and you have to check the lift to adjust the links to get it right.
nashrcracer is offline
Old 05-22-2012, 07:09 AM
  #2537
ByteStream's Avatar
Here is a better look at the new center servo mount option .. it places the servo about 1mm off the chassis. Looks like the servo nub was never there lol.
ByteStream is offline
Old 05-22-2012, 07:13 AM
  #2538
MikeXray's Avatar
Trader Rating: 73 (100%+)
How rigid is it, if you hold the wheels will it flex before the servo saver?
MikeXray is offline
Old 05-22-2012, 07:27 AM
  #2539
R/C Tech Elite Member
Jamison R's Avatar
Trader Rating: 66 (100%+)
It is more rigid than I expected.
Jamison R is offline
Old 05-22-2012, 08:24 AM
  #2540
ByteStream's Avatar
If you hold both wheels dead center between a vice and turn with the transmitter, there is a very small amount of flex and the servo saver slips.
If you are at full lock and push the wheels in the other direction .. only the servo saver slips.
As mentioned, it is pretty rigid .. surprisingly so.
Old 05-22-2012, 06:24 PM
  #2541
Trader Rating: 38 (100%+)
What's the easiest way to cleanly remove the nub?
or8ital is offline
Old 05-22-2012, 07:37 PM
  #2542
Regional Moderator
CarbonJoe's Avatar
Tick off the wife or girlfriend?
Dremel and cut off wheel.
CarbonJoe is offline
Old 05-22-2012, 11:43 PM
  #2543
Ha!
I was afraid you would say a cut off wheel.
or8ital is offline
Old 05-23-2012, 04:05 AM
  #2544
Regional Moderator
CarbonJoe's Avatar
Ha!
Be sure to wear a dust mask. CF dust in the lungs is bad.
Old 05-23-2012, 04:24 AM
  #2545
CF in your lungs doesn't make you faster? I thought if you followed it with a paragon chaser you were all good?
or8ital is offline
Old 05-23-2012, 08:02 PM
  #2546
CristianTabush's Avatar
Default DCj's for XRAY TC's
We are working on DCJ's for different cars at the moment, the XRAY is at the top of the list.
Nothing fancy here, just affordable, durable DCJ's made out of 12.9 steel, like our TC6 ones.
What would the interest be like for DCJ's that cost 39.99 per pair and are fully rebuildable? Please let me know...
CristianTabush is offline
Old 05-23-2012, 08:17 PM
  #2547
defcone's Avatar
Trader Rating: 15 (100%+)
That'd be awesome! Doing what spec r does with the clips will be nice too.
defcone is offline
Old 05-23-2012, 09:14 PM
  #2548
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
rdlkgliders is offline
Old 05-24-2012, 06:19 AM
  #2549
Trader Rating: 93 (100%+)
I just got the spec r DCJ's and they look real nice. I like the use of rings instead of the susceptible grub screws that have to be checked often. Some have had problems with spec r in the past but these v.2's look up to par.
it would be nice if you can make yours use the regular 5x10x4 bearing instead of the 5x10x3 inner bearing that the spec r's have to use.
Markus is offline
Old 05-24-2012, 06:29 AM
  #2550
Why do the Spec R use a narrower bearing? Is the axle too short? Isn't it the steering block that dictates the dimension of the bearing needed?
Ok, we will get the test units with retaining clips instead of set-screws. Otherwise, dimensionally, they will be identical to 52mm XRAY DCJs.
