Like Tree1Likes
Xray T3 2012
Old 04-26-2012, 05:41 PM
  #2311
stro3579's Avatar
Trader Rating: 20 (100%+)
Originally Posted by EAMotorsports
I think the new design that is coming out is great. I think more will be doing something similar too.
To me the serpent one sucks because you cant even use a servo saver for those that want one. Just my opinion.
The new Yokomo only comes with one servo mount for the inside and servo tape as your using. So there is nothing wrong with that method either as it allows flex too.
EA
Why wouldn't you use both mounting post on servo? What happens when using servo tape and just using one post?
stro3579 is offline
Old 04-26-2012, 05:57 PM
  #2312
syndr0me's Avatar
Trader Rating: 32 (100%+)
The nub drags on the ground and makes cars unstable in the sweeper if you don't take a perfect line. I cut mine off after arguing against this for a while and it was true. The car is better without it. I'm using shoe goo and the inside mount until XRay releases the new piece.
syndr0me is offline
  #2313
artwork's Avatar
Trader Rating: 88 (100%+)
If you cut off the nub you cannot use the other post. Servo tape works well to keep the servo from twisting.
artwork is online now
Old 04-26-2012, 06:38 PM
  #2314
stro3579's Avatar
Thanks, after observing my car really good. I can see where it has touch the carpet. I will cut mines as well. How are you gonna get the shoe goo off your chassis?
stro3579 is offline
Old 04-26-2012, 06:45 PM
  #2315
syndr0me's Avatar
Kung-fu grip.
syndr0me is offline
Old 04-26-2012, 06:46 PM
  #2316
syndr0me's Avatar
I wouldn't say cutting it is crucial, it's not a life changing difference, and it may very well not be a big deal on your track.
syndr0me is offline
Old 04-26-2012, 06:50 PM
  #2317
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
BUT you won't know until you try
hanulec is offline
Old 04-27-2012, 12:06 PM
  #2318
dr_hfuhuhurr's Avatar
Trader Rating: 95 (100%+)
Can someone post some pics of their anti-tuck solutions? Rebuilding my T3 '12 after the season here ended and have changed a few things around. Want to make sure I put something in place to prevent tuckage...Lost a TON of time in my last main with a body tuck (and a marshall that wasn't paying attention).
dr_hfuhuhurr is offline
Old 04-27-2012, 12:55 PM
  #2319
R3VoLuTiOn's Avatar
Trader Rating: 29 (100%+)
cut the wheel wells so there's 3-5 mm body clearance to the left and right of the tire.
then put your body clips 1 hole above where they would be snug on the body.
lastly, don't hit anything
R3VoLuTiOn is offline
Old 04-27-2012, 07:44 PM
  #2320
I have the wheel wells trimmed properly. Will try the loose body posts. I didn't hit anything. Got tagged in the rear by another racer.
Old 04-29-2012, 03:45 AM
  #2321
Jamison R's Avatar
Trader Rating: 66 (100%+)
Will the 50mm ecs driveshafts work on the stock spool? Or do I need to shim the outdrives? I have read people buying different outdrives and using a shim.
Jamison R is offline
Old 04-29-2012, 06:13 AM
  #2322
Bigz84's Avatar
Trader Rating: 24 (100%+)
Yes it will work, but w/ the composite outdrives, they tend to break in a heavy hit because the shaft is not far enough in the outdrive. I did shim the outdrive 1mm out and that helped solve that issue. Hope that helps.
Bigz84 is offline
Old 04-29-2012, 06:15 AM
  #2323
ByteStream's Avatar
You need to shim out the plastic outdrives, or you can get aftermarket ones that are a direct replacement i.e Nikita Outdrives.
ByteStream is offline
Old 04-29-2012, 07:07 AM
  #2324
Jamison R's Avatar
You have to use the plastic driveshaft pieces when you switch to aftermarket correct?
Old 04-29-2012, 08:00 AM
  #2325
Suspended
Correct
R Dodge is offline
