Like Tree1Likes
Xray T3 2012
Old 04-18-2012, 02:10 PM
  #2251
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by EAMotorsports
At the ETS we were as much as 4mm at the top spaced out. It smooths the car out in high speed sections of the track such as sweepers and chicanes. And the chicane at ETS was brutal!
EA
I still can't wrap my head around the idea of this making a noticeable change, damn toy cars are sooo sensitive!
MikeXray is offline
Old 04-18-2012, 02:19 PM
  #2252
stro3579's Avatar
Trader Rating: 20 (100%+)
Default Spacers
Are you guys referring to the spacers between the shock tower and shocks? And lower at and shocks?
stro3579 is offline
Old 04-18-2012, 02:27 PM
  #2253
Fred Hubbard's Avatar
No just between the tower and shocks.
EDIT: I only space out the top.
Fred Hubbard is offline
Old 04-18-2012, 02:29 PM
  #2254
Team EAM
Trader Rating: 79 (100%+)
AMEN!! But it did make a difference doing it back to back runs. Its very minor though. Its not going to net you the magic .2 everyone always looks for I guess if you look at a Tamiya shock compared to our shock the Tamiya probably has 2-3mm built in because of the ball mount it has where ours sits really flat against the tower.
Between the Upper shock mount and tower and lower shock mount and arm. Most of the time you do it even. But we were 4 on upper and 3 on lower front and rear. Some went back to 2 upper and lower.
EA
EAMotorsports is offline
Old 04-18-2012, 02:30 PM
  #2255
Team EAM
Thats what I do if its only 1mm at top. Anymore I do both parts. Especially if its 3-4mm on top.
EA
Old 04-18-2012, 02:43 PM
  #2256
stro3579's Avatar
Default Shims
What effect does this give the car?
stro3579 is offline
Old 04-18-2012, 02:50 PM
  #2257
Johnny Wishbone's Avatar
Default Art
Hey Art, congrats on your win at the Regionals.
Johnny Wishbone is offline
Old 04-18-2012, 03:14 PM
  #2258
artwork's Avatar
Trader Rating: 88 (100%+)
Thanks Gary...My car was super dialed. So easy to drive and really fast. I have posted my setup on Xray's website in case anyone cares or wants to see it.
http://forum.teamxray.com/xform/inde...&setup=t3_2012
I made a pretty critical error on my 13.5 car, which I found after the fact, but was still able to manage a 2nd place overall. My car was pretty wicked to be honest!
artwork is offline
Old 04-18-2012, 03:33 PM
  #2259
EA
See the above response from EA.
Old 04-18-2012, 03:42 PM
  #2260
UrabusDenis's Avatar
Just to check, anyone here running on foams? I'd like to compare some simple set up changes with different drivers...
UrabusDenis is offline
Old 04-19-2012, 01:01 AM
  #2261
NR
NR's Avatar
Trader Rating: 52 (100%+)
Question,
What is the best way to check for bent bulkheads? Via putting the car on the blocks? or stripping the car and checking the blocks individually?
Thank you
Regards
Nathan
NR is offline
Old 04-19-2012, 01:16 AM
  #2262
nerdling's Avatar
Originally Posted by NR
Question,
You've answered your question right there my friend...
nerdling is offline
Old 04-19-2012, 02:06 AM
  #2263
NR
NR's Avatar
Damn
NR is offline
Old 04-19-2012, 06:52 AM
  #2264
RC MARKET's Avatar
A+ New Shim for T3
RC MARKET is offline
Old 04-19-2012, 06:53 AM
  #2265
Just wanted to throw this small bit of info i learned out to others.
Check your rear hinge pins, I was struggling with the rear end of the car making all types of changes to keep it planted & what I found was one of the pins slightly bent, could not notice it by eye but it did roll funny when taken off the car. I have taken for granted how strong this car is & after 10 weeks of wacking walls i bent some stuff lol,
Shortbusallstar is offline
