Like Tree1Likes
Xray T3 2012
Old 03-16-2012, 11:34 AM
  #1861
gonzo416's Avatar
Trader Rating: 39 (98%+)
gonzo416 is offline
Old 03-16-2012, 11:45 AM
  #1862
entitymugenmtx's Avatar
Trader Rating: 85 (100%+)
Originally Posted by DOTMAN View Post
speedtechrc sells it and servo connectors and pins
If you can't wait there is always ebay.
http://www.ebay.com/itm/Hobby-Connec...item20ba67bd47
entitymugenmtx is offline
Old 03-16-2012, 01:43 PM
  #1863
Default Drive shaft replacement plastic caps #305241
On page 17 of the manual it says:"DO NOT use the plastic caps with composite solid axle included in the kit. The new #305241 3.5mm plastic caps are for use ONLY with GEAR diffs, ALU ball diffs, or the XRAY Multi-Diff."
How weard is that?! So in the kit are plastic caps that you can't use!
So which plastic caps do you have to use, what is the partnumber and why are they not in the kit?!
Kensei is offline
Old 03-16-2012, 01:49 PM
  #1864
Xpress's Avatar
The factory spool cups accept the axle drive pin without a blade.
Xpress is offline
Old 03-16-2012, 02:09 PM
  #1865
Another question:
is "308019 Set of Shock Shims & Nuts" in the kit?
Any preferences as to what servo to use in T3'12 in combo with Sanwa MT-4?
Was thinking of Futaba BLS551.
Kensei is offline
Old 03-16-2012, 02:12 PM
  #1866
Okidoki.
Also when using optional ECS Drive Shafts?
Kensei is offline
Old 03-16-2012, 02:34 PM
  #1867
Last edited by Team_Krusty; 03-16-2012 at 03:59 PM. Reason: misunderstood the question being asked
Team_Krusty is offline
Old 03-16-2012, 02:44 PM
  #1868
Xpress's Avatar
Okidoki.
Yes. With the stock spool outdrives you do not use driveshaft "blades." If you would prefer to use blades on the front driveshafts you will need to purchase the optional alloy or steel spool outdrives.
Xpress is offline
Old 03-16-2012, 04:53 PM
  #1869
UrabusDenis's Avatar
Do blades have to be used with alloy outdrive spool?
UrabusDenis is offline
Old 03-16-2012, 05:24 PM
  #1870
Skiddins's Avatar
Yes, all the other outdrives use the blades.
Skiddins is offline
Old 03-16-2012, 05:25 PM
  #1871
Skiddins's Avatar
The same blades are used on the rear driveshafts for the gear diff
Skiddins is offline
Old 03-17-2012, 01:29 AM
  #1872
New wire job
Old 03-17-2012, 11:16 AM
  #1873
I have my shafts without blades on alloy R1wurks spool outdrives and they are working without problems. However I respect you very much as a poster on this thread so I will put blades (I received a replacement set today) . My question is, why do they have to be used? Is it because of metal/metal contact or too much play?
Also, I'd like some simple set up changes to increase on-throttle control? Softer springs maybe?
Old 03-17-2012, 12:06 PM
  #1874
Essnowyt's Avatar
The blades are used to protect the expensive turned steel/aluminum parts. You can drive with out them, but you are slowing going to wear the metal out drive cups. The plastic blade acts as shock/buffer in the drive line. They are, "Consumable" as they do wear. Replacing a $5.00 set of plastic blades is much better then sloppy worn out steel/aluminum drive cups.
In the past I had a hot bodies cyclone hara edition and it had the V2 steel front out drives on the one way. The cyclone did not use blades. After a year of racing they were shoot. You would hear honorable noises from the front of the car. This was not the CVDs, but the drive cups. Handling was significantly effected too. When I tried to replace the drive cups, no US distributor had the V2 drives in their inventory or even their parts id. No body knew about the V2 drives parts.
Moral of my story; If you can use blades, do so!
Snowy.
Essnowyt is offline
Old 03-17-2012, 05:07 PM
  #1875
theatriks's Avatar
How often do you guys rebuild your ECS shafts?
theatriks is offline
