Like Tree1Likes
Xray T3 2012
Old 02-24-2012, 10:55 AM
  #1591
gonzo416's Avatar
Trader Rating: 39 (98%+)
I got it. Used a bent needle nose pliers. Didn't think it was going to work.
gonzo416 is offline
Old 02-24-2012, 12:00 PM
  #1592
kuruption's Avatar
Trader Rating: 24 (100%+)
Originally Posted by CarbonJoe
New servo mount..
http://www.redrc.net/2012/02/xray-t2...nt/#more-52474
Does this lift the servo off the chassis? Hard to tell from the pictures.
Doesn't look like it... the outside servo mount just doesnt bolt to the chassis leaving a small gap. Better pictures on Xray's website... http://www.teamxray.com/teamxray/new...&kategoria=738
kuruption is offline
Old 02-24-2012, 02:00 PM
  #1593
M-Technic's Avatar
Trader Rating: 15 (100%+)
It must lift it off, because it says it allows you to mount the servo without touching the chassis.
M-Technic is offline
Old 02-24-2012, 02:15 PM
  #1594
Fred Hubbard's Avatar
Originally Posted by Matt W
So are you saying that when you make the front shocks more vertical you take away the initial steering but when you stand the rear up it gives more rear grip? Is that initial rear grip or middle to exit grip?
It's been about 2 years since I last tested shimming the rear shocks out so I'm not 100% certain anymore which part(s) of the corner it affects. I will try it tomorrow and let you know.
Fred Hubbard is offline
Old 02-24-2012, 02:16 PM
  #1595
Originally Posted by locked
Thanks Fred. I thought I might have it wrong, but since my car is an absolute pleasure to drive, I probably wouldn't have changed it even if it was "wrong"
Thanks Mike. Yeah, you're right, it would depend on wheelbase and inboard toe.
LOL
Old 02-24-2012, 02:27 PM
  #1596
syndr0me's Avatar
Trader Rating: 32 (100%+)
Does this mean I can cut the servo nub off?
syndr0me is offline
Old 02-24-2012, 03:48 PM
  #1597
Sure
Old 02-24-2012, 03:57 PM
  #1598
syndr0me's Avatar
Originally Posted by Fred Hubbard
Sure
It might grind itself off on the carpet soon.
syndr0me is offline
Old 02-24-2012, 04:28 PM
  #1599
Old 02-24-2012, 04:37 PM
  #1600
Con
Mine ground itself off on the edge of a dremal wheel
Con is offline
Old 02-24-2012, 05:56 PM
  #1601
Does anyone know how the new servo mount would fit a t3 '10 car?
bgrick is offline
Old 02-24-2012, 07:55 PM
  #1602
Does anyone have tried the new 2.0mm chassis and the new 1.6mm upper deck?
minez is offline
Old 02-24-2012, 07:57 PM
  #1603
Old 02-24-2012, 08:59 PM
  #1604
elee32's Avatar
Trader Rating: 18 (100%+)
not likely, looks like it connects to the dual bellcrank steering system like on the t3 11 and t3 12
elee32 is offline
Old 02-25-2012, 03:52 AM
  #1605
Default 1 degrees rear hubs
can someone tell me the benifits of using one degrees rear hub to get three degrees rear toe, instead of only using inboard spacers.
matt prigmore is offline
