Like Tree1Likes
Xray T3 2012
Old 02-24-2012, 07:09 AM
  #1576
Could you please stop spamming this crap all over the place? I don't think anybody cares.
halldor is offline
Old 02-24-2012, 07:39 AM
  #1577
Default shimming rear shock!!
How does adding a shim between the rear shock and tower affect the cars handling?
Matt W is offline
Old 02-24-2012, 08:58 AM
  #1578
Fred Hubbard's Avatar
I care
Fred Hubbard is offline
Old 02-24-2012, 09:00 AM
  #1579
Makes the car a bit easier to drive, more predictable and consistent. It generates less initial steering but the car will both square up and generate a bit more on-power steering.
Old 02-24-2012, 09:04 AM
  #1580
defcone's Avatar
Trader Rating: 15 (100%+)
What's a relative easy way to take 0.5mm off each side of suspension holders?
defcone is offline
Old 02-24-2012, 09:08 AM
  #1581
Signup for Paul LeMieux's Advanced Dremel Course #301
Use a Dremel.
Old 02-24-2012, 09:12 AM
  #1582
locked's Avatar
hmm. I have mine the opposite. In the rear I shimmed between the arms and the bottom of the shocks only. None between the rear tower and the shocks, but in the front I shimmed between the top of the shocks and the tower. To make both a bit more vertical when viewed from the side.
I found it made the car easier to drive. I suck at explaining handling characteristics.
Just surprised you shim between the tower and the rear shocks. This would angle them more.
locked is offline
Old 02-24-2012, 09:16 AM
  #1583
MikeXray's Avatar
Trader Rating: 73 (100%+)
That would depend on your wheelbase settings.
MikeXray is offline
Old 02-24-2012, 09:20 AM
  #1584
I just exhibited what happens when you FAIL to fully read a post...DOH!!!! What I wrote pertains to the front only.
  #1585
Shimming the REAR out, that is both the top and bottom of the shock, should generate more rear grip.
Old 02-24-2012, 10:03 AM
  #1586
locked's Avatar
Thanks Fred. I thought I might have it wrong, but since my car is an absolute pleasure to drive, I probably wouldn't have changed it even if it was "wrong"
Thanks Mike. Yeah, you're right, it would depend on wheelbase and inboard toe.
locked is offline
Old 02-24-2012, 10:22 AM
  #1587
Regional Moderator
CarbonJoe's Avatar
New servo mount..
http://www.redrc.net/2012/02/xray-t2...nt/#more-52474
Does this lift the servo off the chassis? Hard to tell from the pictures.
CarbonJoe is offline
Old 02-24-2012, 10:46 AM
  #1588
So are you saying that when you make the front shocks more vertical you take away the initial steering but when you stand the rear up it gives more rear grip? Is that initial rear grip or middle to exit grip?
Matt W is offline
Old 02-24-2012, 10:48 AM
  #1589
gonzo416's Avatar
Trader Rating: 39 (98%+)
Anyone know how to extract the universal ball that goes thru the hole in the top of the shock. The ball is supposed to go thru the side with the shiny ring around the hole. Who I bought it from assembled it wrong. The shock is supposed to have some play side to side, but it is stiff. That's how I realized it was assemble wrong.
gonzo416 is offline
Old 02-24-2012, 10:55 AM
  #1590
Regional Moderator
CarbonJoe's Avatar
Put a screw through it and mount it to something (like to the shock tower), and lift up. The ball should pop out. You may need to mount it backwards since the ball was inserted backwards.
