Old 11-18-2004, 04:41 PM   #1
Freddybnj_2004's Avatar
Default Bushings vs Bearings
Hey guys.. I was rebuilding my diffs and wanted to know if it's okay to replace the gold 3/16x5/16 bushings in the diff with bearings? Will it make a big difference or is there a reason I shouldn't .... Don't even know where to get the bearings from but was just wondering?
Freddybnj_2004 is offline   Reply With Quote
Old 11-18-2004, 04:46 PM   #2
koabich's Avatar
Send a message via Yahoo to koabich
Yes, you can replace bushings with bearings in the diff. Will you notice any performance difference at the track with bearings...probably not. But the diff should be a little smoother and a little lighter with bearings.
Also, bushings wear out and they might not fit as precise after a while, where bearings in a diff will last forever.
koabich is offline   Reply With Quote
Old 11-18-2004, 04:49 PM   #3
howard hudson's Avatar
R/C Tech Charter Subscriber
Default Re: Bushings vs Bearings
If your talking about the tc3 composit diffs NO stay with the bushings. unless you can find bearings the same width as the bushings.
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline   Reply With Quote
Old 11-18-2004, 04:57 PM   #4
koabich's Avatar
Default Re: Re: Bushings vs Bearings
Associated sells bearings for both the composite diffs and the steel diffs and yes they are a different part number's.
Just remember, if this is an Associated car, the bushings/bearings for the steel outdrives are a different size than those used for the plastic outdrives!
Old 11-18-2004, 05:05 PM   #5
Great thanks guys
Old 11-18-2004, 05:22 PM   #6
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Remember, those bearing only spin a few degrees at a time, the difference between how far the outside tire travels versus the inside tire.
Can you replace them with bearings = yes.
Will you notice any difference with bearings = probably not.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Various Bits & Bobs (Bearings, Bushings, B4 Bits, Tamiya Bits) thecrow2k R/C Items: For Sale/Trade 0 06-02-2008 09:09 AM
going from bushings to bearings jedsled Electric Off-Road 4 03-04-2008 11:11 PM
Swap Motor Bushings for Bearings Jake S Electric On-Road 12 03-21-2007 11:28 PM
FS roller mini t, needs driveshafts, rear hubs, and bearings(or bushings) t to the maxx2 R/C Items: For Sale/Trade 3 01-16-2006 06:21 PM
bushings? SPC Racing Electric On-Road 7 03-06-2004 06:14 AM
