Old 11-18-2004, 11:05 AM   #1
Driver1's Avatar
Send a message via AIM to Driver1
Default Big race question
Going into a big race....one that if u do well will make u look good...
what do u start to do a few weeksn in prepare..
Driver1 is offline   Reply With Quote
Old 11-18-2004, 11:09 AM   #2
berger's Avatar
R/C Tech Charter Subscriber
Rebuild the car. Spray some new shells Even if i drive bad i can look good.
berger is offline   Reply With Quote
Old 11-18-2004, 11:27 AM   #3
Chill Will's Avatar
Exactly
Also call the track and find out what tires work the best, if it's not a handout race. If it's a onroad race find out what body works the best so you won't have to buy 4 or 5 bodies to get one that works.
Chill Will is offline   Reply With Quote
Old 11-18-2004, 03:11 PM   #4
what kind of car do you run?
i would pefer the nemesis body if its on road
x-ray_tony is offline   Reply With Quote
Old 11-18-2004, 04:02 PM   #5
Nrctc3's Avatar
Send a message via AIM to Nrctc3 Send a message via Yahoo to Nrctc3
I like to get as much work done as possible while I'm still at home. Like setup, motor work & all that fun stuff. Then it allows you more time at the track to find that "hot setup". Not to mention, you wont have to be running around looking for help, parts & stuff.
Nrctc3 is offline   Reply With Quote
Old 11-18-2004, 06:52 PM   #6
Super Moderator
Grizzbob's Avatar
Exactly, learn as much as you can about the track you'll be racing on, to do some car setup before you go there, & clean, rebuild, relube, refill, etc. everything you can before you go. So as soon as you get there & set up, you can get on the driver stand ASAP, & spend all the time you can driving, the more track time, the better....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 11-18-2004, 07:00 PM   #7
Driver1's Avatar
thanks guys....
what about mentally
Old 11-18-2004, 07:09 PM   #8
howard hudson's Avatar
Originally posted by Driver1
thanks guys....
what about mentally
Thats RIGHT!!! You have to be crazy to spend gobs of money on this Hobby. Hell Ive been a nut case for years now!!!!!!!!!!!!!!!!!
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline   Reply With Quote
Old 11-18-2004, 07:35 PM   #9
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
The more track time you get under your belt at that particular track...the more confident you will become....thus more mentally prepared you will be. Find a setup that allows you to drive the car hard and at the same time feel very confident. Once your setup is half way decent then its just track time.
I like to go with a couple of motors....maybe 3. Switch them out after every run so they all have a chance to cool down and won't fade as quickly.
Seriouesly though, work on hitting your points every turn of every lap....again, the more confident you are with the car, the more mentally prepared you will be and the faster you will be able to drive.
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 11-18-2004, 10:00 PM   #10
POOKYT's Avatar
Doritos and Mt.Dew! Lots of Dew! LOL
Really I like to show up with the car as ready as possible and if I can I like to have 1 or 2 practice packs charged and ready to hit the track ASAP. Even a car half way set up will let you get used to the track layout. Good Luck.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 11-18-2004, 10:16 PM   #11
Send a message via AIM to A-Ko
thanks guys....
what about mentally
If you can get prepared; parts, practice, driving, tires, batteries, motors, bodies. That is most of the battle.
The next thing is setup. If you can goto any track and be close with your setup without major thrashing that is a big deal. If you can find a track close to the big race surface and figure out fast setups that helps too.
Depending on the race you need to maximize your time on the track. I burn butterflies with major track practice a day or two before the race starts. Chasing race chassis setups can ruin your mental game over a big race weekend, when you should really focusing on motor, gear ratio and tires.
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 11-18-2004, 11:06 PM   #12
ford_racing's Avatar
Send a message via MSN to ford_racing
Cleaning cars out is very important
Try not to run more than 2 classes in a day eg 540 and stock
Have several spare motors that have been run in so if one fails it's easy to swap them over
Bodyshells aren't that important till you get into stock / mod, then you need a new shell for aerodynamics sake
if you're only racing 540 or equivelant an old body will be fine, just one with not alot of use / cracks / damage etc. paint flaking off won't hurt your times, it mightn't look the best but your car will peform better if you are used to driving that particular shape shell
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 11-20-2004, 01:30 AM   #13
pink pac man's Avatar
i whould bring food and drink cos at least if your car stuffs up and you cant drive it anymore you can sit back and watch the race
and paint up sum bodies.........not cos of aerodynamics sake but cos its fun and they look so cool when there not scratched up
pink pac man is offline   Reply With Quote
Old 11-20-2004, 06:37 AM   #14
rebuild car, make electronic wires nice and tidy, spray a few shells, take some cash, make lunch then go racin
Chazz
Chazz is offline   Reply With Quote
Old 11-20-2004, 08:11 AM   #15
Originally posted by POOKYT
Doritos and Mt.Dew! Lots of Dew! LOL Brant
I would prefer red bull or rockstar energy drinks
make sure you have a well balenced breakfast to keep up concentration. Good luck
Tony Szep is offline   Reply With Quote
8ight t race roller question jjracing Nitro Off-Road 2 05-01-2008 09:52 AM
Roar race question RaceAce701 Racing Forum 1 07-10-2006 04:20 PM
race truck question 2mcgrath Monster Trucks 22 04-01-2005 03:26 PM
Race schedule question Ikester MARCCA Discussion 3 03-04-2005 09:02 AM
My first race coming up, battery question Galactik Electric On-Road 6 08-17-2004 03:04 PM
