Tamiya 1/12 R/C RM-01 "Racing Master" >
Like Tree14Likes
Old 12-01-2012, 04:33 AM
  #751
Radio Active's Avatar
Originally Posted by addicted2blue
I think i've found a solution to use the tamiya wheels and tires and still have plenty of ride height while you can use the tires very close to the wheel itself.
Still need to verify this by building the car to a normal ride height of 4mm or higher/lower to be sure this is possible.
I did try something but still needs to clear this out so i can be sure of it
I will keep you guys informed about this
Waiting with baited breath...
Radio Active is offline
Old 12-01-2012, 10:43 AM
  #752
Wel as i said i did try somerthing to be able to use tamiya tires/wheels a little bit longer and still maintain the usual ride height. Therefor you need the F104 metal front upright and the RD special king pin set, when using a 2mm spacer on top of the metal upright you are able to true dwn the front tires to a minimum size of 40mm.
When you do this you have the minimum ride height of 3mm.
When using the RD special king pin set you need to place the front spring on top of the metal front upright or spacer. Depending on the ride height.
When you want to try this you still need to modify the front suspension arm by cutting a small piece of triangle away, this needs to be done otherwise the front metal upright will bind up when turning into a corner.
Hope this makes any sence to you guys :-)
addicted2blue is offline
Old 12-01-2012, 07:39 PM
  #753
Test Driver's Avatar
Thanks for that info. I think Radio Active and myself will be looking into those parts for a project we are currently working on.
Test Driver is offline
Old 12-04-2012, 04:34 AM
  #754
celt's Avatar
Originally Posted by RedBullFiXX
Oh My
wow...that rig is just beautiful and is what 1/12 scale should be.
Well done...placing an order!
celt is offline
Old 12-11-2012, 07:46 AM
  #755
Trader Rating: 21 (100%+)
Hey everyone, I'm selling my spare RM01 with almost every hop-up. Never ran once, no electronics even installed.
http://www.rctech.net/forum/r-c-item...l#post11541856
TamiyaMatt84 is offline
Old 12-12-2012, 04:51 AM
  #756
celt's Avatar
Default 2013 TCS
I've a question for those that have built and run this kit.
I'm looking to add a second class to TCS this year, and 1/12 could make sense, with my primary class being F1.
I see in the 1/12 TCS rules, they allow any wheel, any foam. (read non Tamiya) I'm really not interested in retrofitting non Tamiya tires and wheels. I was somewhat disappointed that the didn't make everyone run all Tamiya stuff. Run the car as designed, with the wheels and tires designed for this chassis.
So....
How much hurt am I going to be in if I run this chassis with some reasonable hop-ups, but with Tamiya tires and wheels - keep the geometry as design intended. I ran 1/12 exclusively a few years back - always been my favorite class, but the tires just got nutty. One run and pitch them kind of turned me off.
This looks like an awesome car, I would love to own it and race it, I'd just like to run it as designed. I know some agree in allowing any tire / wheel. Don't care to get in that argument with anyone, it's just not where I want to go. If I'm going to play the tires game again, I'll get a truer and a CRC chassis for that.
celt is offline
Old 12-12-2012, 05:50 AM
  #757
bakaguyjean's Avatar
So....
The only real problem is the rear hubs that you have to use for Tamiya wheels are very heavy,the hubs are not used when you use non Tamiya wheels.
Only TCS in America allows wheels other than Tamiya. I think American TCS really killed this car by allowing different wheels and bodies. TCS in America for the RM-01 isnt really a Tamiya class,it has none of the appeal of a TCS class and really is a joke.
My two cents
bakaguyjean is offline
Old 12-12-2012, 06:22 AM
  #758
subaru73's Avatar
Trader Rating: 42 (100%+)
Default Rm01
So....
Actually the rules state Tamiya tires only go to the tcs site and look for the link to the rules not the one that is listed the car works well with kit rear and option front tires as far as hop ups the alum motor mount,pitch and roll dampners and springs that should get you going.
subaru73 is offline
Old 12-12-2012, 07:09 AM
  #759
Trader Rating: 28 (100%+)
So....
The TCS America rules have been amended for 2013 and now allow only Tamiya tires and wheels. That said the car works well, as proven by a local racer (D Berger) that I believe drove a box stock RM01 to a class win at the Tamiya America track last year?
madjack is offline
Old 12-12-2012, 07:15 AM
  #760
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
My two cents
Celt:
Tamiya Tires and wheels are required for TCS from 2013 on
In the first year (2012) it was thought that getting 12th scale racers on board would be easier with less restrictive rules
Baka, do you race TCS in the USA ?
12th and RM-01 participation are growing in TCS
In 2013, I'm sure it will be even more successful
RedBullFiXX is offline
Old 12-12-2012, 09:22 AM
  #761
celt's Avatar
Celt:
In the first year (2012) it was thought that getting 12th scale racers on board would be easier with less restrictive rulesl
If this is the case than I respectfully retract my concerns.
I think limiting the tire to Tamiya offerings makes the class much more attractive.
Thanks guys for clearing that up.
celt is offline
Old 12-12-2012, 09:58 AM
  #762
Nice thing about Tamiya kit & option Foams, they work well everywhere
Old 12-14-2012, 12:00 AM
  #763
Hey RedBull,
When you use the AE side springs on the RM-01 do you crimp them so they fit on the retainers better, or do you use AE retainers instead of the Tamiya ones? If the former how do you ensure that you don't warp the spring when crimping it?
Old 12-14-2012, 09:16 AM
  #764
Originally Posted by Radio Active
Hey RedBull,
I use a drop of ca on the spring if its loose
It's easier to keep the spring straight & square this way
Just a tiny twist and the spring is easy to change
Old 12-14-2012, 05:17 PM
  #765
Thanks.
