Old 09-14-2011, 12:47 PM   #1
Default Help with HPI Sprint
Ok I'm new and I searched*before this and looked in the rockie zone.
I bought an HPI Sprint from my buddy that he got from a friend for his son,neither of them know anything about Rc cars. I got it with no shell,it has the full carbon body and a new Tazer 12T ESC. I found out how to set it but the remote is a Jr xr2. I read about the settings for it in some threads. I can't get it to go * *BUT shouldn't the car be able to roll when it's turned off ? *Or no? Because it's hard to push and to spin the big gear that spins the motor!
Churn Dasher is offline   Reply With Quote
Old 09-14-2011, 01:40 PM   #2
Sorry I didn't put this in the Rookie zone if it can be moved there that's cool.
Old 09-14-2011, 02:09 PM   #3
sosidge's Avatar
When the pinion gear (on the motor) is meshed to the spur gear there may be some resistance to moving the car. You should be able to turn the motor over by hand though.
Try taking off the pinion (or moving the motor away from the spur), the car should then roll freely.
If it won't go at all it's more likely a problem with the electrics than a problem with the drivetrain. Check the battery is charged and everything is wired and set up correctly.
Old 09-14-2011, 02:39 PM   #4
What's the best way to bench test the motor?
Old 09-14-2011, 02:40 PM   #5
sosidge's Avatar
With a brushed motor you can connect it directly to a battery pack.
Old 09-17-2011, 06:08 PM   #6
Ok the motor works great and all the belts and wheels. So I guess now its the remote settings because the ESC is new and easy to set.
HPI Sprint 2 Revlimit Electric On-Road 75 06-11-2016 12:41 AM
HPI Sprint 2 Flux any good? Cheezburger Electric On-Road 25 05-28-2013 03:23 PM
hpi sprint 2 sport questions (parts interchange or upgrades) redron123 Electric On-Road 13 02-22-2011 01:52 PM
help with hpi sprint and 9T double motar. Dayne Electric On-Road 6 05-05-2003 02:56 AM
