Old 11-15-2004, 05:47 PM   #16
Originally posted by kh15
what size tires are you running because according to the gear chart you tc3 should be well over 40mph with a 30/700 gear combo and a 64mm tire (thats what i use) and the 34,800rpm the ss5800 produces?
do 64mm tires come stock with the car? i ahve another questions about getting pinion gears on. i can never get the screw to stayu in. then when im drving my gear comes off. what should i do?
tc3novak is offline   Reply With Quote
Old 11-15-2004, 05:50 PM   #17
i think if i use a 70/30 for my motor wont that be overgeared
Old 11-15-2004, 09:25 PM   #18
ohhh my bad i thought you said 70/30
kh15 is offline   Reply With Quote
Old 11-15-2004, 09:45 PM   #19
Send a message via AIM to waterblast02
Put some locktite on that screw. Its what I did and it hasnt flung out yet since I did.
waterblast02 is offline   Reply With Quote
Old 11-17-2004, 05:31 PM   #20
thanks i did that and it worked!
Old 11-18-2004, 04:54 AM   #21
PaZ
PaZ's Avatar
TC3 almost every aluminium upgrade going
Team Paradigm stock
LRP V7.1
KO-Propo PS2117 ( i think ) cost me 85 quid anyway
Pro-Trak charger
Team Titan TC2 shell
Team TJ cells
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 11-18-2004, 04:20 PM   #22
cool! what upgrades can u get to make your car go faster other than a good motor and changung the gears? im new to rc so i dont know.
Old 11-19-2004, 04:22 AM   #23
PaZ
PaZ's Avatar
Personally i found that the ally steering rack with bearings make a massive handling improvement as the ally doesnt bend like the plastic/graphite ones. The ally f+r hubs and carriers are a good idea as they dont snap or bend cause there so small and strong. The ally wishbones are a very strong but just make sure you run the standard plastic parts to hold the wishbone pins in under the diffs cause if you have a hard hit the ally will not snap so the plastic bits will and they are very easy amd cheap to replace. Also it makes your ride look sweet but its costs alot but is well worth it in the end
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Old 11-20-2004, 12:17 PM   #24
PaZ
PaZ's Avatar
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Old 11-20-2004, 02:22 PM   #25
jackfast's Avatar
Now, that is a good setup paz
jackfast is offline   Reply With Quote
Old 11-20-2004, 03:24 PM   #26
PaZ
PaZ's Avatar
Thanks lol
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Old 11-20-2004, 04:45 PM   #27
pink pac man's Avatar
Default tc3novak
you could try ceramic bearings............they will make it faster
pink pac man is offline   Reply With Quote
Old 11-20-2004, 05:32 PM   #28
hpipro321's Avatar
ya, but ceramic berings are alot of work and you always have to keep them clean. although they will make the car alot faster. I would just stick with the ones u got unless they are rusted,
hpipro321
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b can you feel the bass? d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
hpipro321 is offline   Reply With Quote
Old 11-21-2004, 12:26 PM   #29
PaZ
PaZ's Avatar
Yea i looked into them but there expensive and hard to get in the UK, so im running a fill teflon kit which are soooooo smooth. Just got a few more ally parts today if u got a TC3 BUY IRS LIGHTWEIGHT DIFF HALVES THEY KICK ASS
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Old 11-27-2004, 01:25 PM   #30
PaZ
PaZ's Avatar
Here it is, just waiting for the wide blue bumper holder, ally front and rear body posts, probably a BMI Blue ETC3 conversion to
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
EPA - ABS and D-Rate NOVICE4EVER Singapore R/C Racers 8 02-11-2008 09:04 PM
rate the burn out MMS1 Chat Lounge 4 12-15-2007 06:32 PM
how would you rate the bk1, bk2 and the cr tony montana Electric Off-Road 3 11-20-2006 06:40 AM
Discharge rate ?'s jrxsracer Electric On-Road 19 03-04-2006 08:35 PM
what is dual rate? me8 Rookie Zone 2 06-14-2004 07:36 AM
