Old 11-15-2011, 05:21 PM   #106
Infinite 12th's Avatar
Originally Posted by peter_robinson View Post
I doubt I can top Wes' race report but here it goes.
Like Bruce said I suffered some very peculiar radio issues once qualifying started. I made it all the way through two days of practice without a hiccup, but I am thankful I got things sorted out.
So after turning a total of 5 laps in the first two rounds of qualifing, I borrowed a radio and receiver and got on the track for round 3. The track had finally grooved into something more normal and no longer felt like we were skipping between old groove from the nats layout and and virgin carpet. My car was way too stiff and the radio was foreign but I still got a decent run in to get resorted back to the top heat.
I round 4 Frank Calandra came out running on top looking to smash his own TQ, but he must has tapped out and/or faded because with only a few small mistakes I found myself in the lead and eventually taking the TQ in the final round by about 1.5-2 secs over Frank, Brian Bodine and Dave Erlich.
Before the mains I made some final small adjustments to my car and was back to something very close to what I ran at the IIC. I lost the lead at times in both of the first to mains but mistakes by the other drivers allowed me to win the event in two.
Find the setup sheet attached. Any questions feel free to post them here.
Does anyone have pictures of how that Tamale pod actually works?
Radical Build Dude
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 11-15-2011, 05:29 PM   #107
peter_robinson's Avatar
Trader Rating: 21 (100%+)
It's easy enough to explain. The bearing holders are machined pieces independent of the pod plates themselves. Where the bearing holders and the podplates meet the mated surfaces are serrated in 0.5mm increments. The bearing holders are slotted from the back so that the holder can moved up and down, be keyed into the pod plate at the desired ride height, and the screws tightened to hold everything together.
There are reference notches etched on the inside of the pod to give the user a visual reference that they are assembling everything correctly left and right. They are not easy to assemble incorrectly.
For orders or inquiries, email [email protected] Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
Old 11-15-2011, 05:36 PM   #108
Very nice explanation
Anyone else have pictures of the guts of the pod show them please
I think this design is to allow people to adjust the pod without taking out the axle? Kinda like the top?
Old 11-15-2011, 07:05 PM   #109
b_recliner's Avatar
Trader Rating: 22 (100%+)
Will that "new old-school" front end bolt on to a crc without modding?
Tracks: Richfield Raceway, LCRC, DRP
Current Cars: Xray t4 '14, Schumacher Cougar KF, Schumacher Mi5, Losi 22 2.0, Losi 8ight E 3.0
b_recliner is offline   Reply With Quote
Old 11-15-2011, 07:37 PM   #110
Donny Lia's Avatar
Awesme Job Wes and Pete!
yes you can adjust without removing the axle.
yes
RocheAwesomatixTrinityKoBsrProtoformTQAvidKimbrough
Donny Lia is offline   Reply With Quote
Old 11-16-2011, 04:16 PM   #111
tim fry's Avatar
Other than the usual things is there any top tips to building an old Skool front end?
tim fry is offline   Reply With Quote
Old 11-16-2011, 06:09 PM   #112
SpeedMerchant's Avatar
There are some pictures of the prototype on the very bottom of this page.
http://www.teamspeedmerchant.com/Rev7Intro.html
The bottom right pic (you can click on it to enlarge) shows the machined channels in the bearing carriers.
SpeedMerchant is offline   Reply With Quote
Old 11-16-2011, 06:17 PM   #113
Hi Tim,
About the only trouble people have with the Old School is snapping in the e-clips, onto the king pins.
Do the top e-clip (under the spring) 1st. A nice pair of small needle nose helps a ton.
To install the bottom e-clip, just slide it underneath the steering block (in between block and arm), and use the back side of your hobby knife to push it on to the king pin.
It's really pretty easy once you get the technique down.
Also, check the steering blocks for any flashing.
That's it.
Have fun.-Bruce
Old 11-16-2011, 06:42 PM   #114
EricF's Avatar
Bruce-
Have or are you going to make or blocks to adjust the camber,castor and ride height of the old skool front end? We talked about it a little in Vegas.
E
AE 12R5.2 & R6(x2) - TC7.1 convert, F6 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 11-17-2011, 01:50 AM   #115
arn671's Avatar
Trader Rating: 15 (100%+)
Thumbs up
Originally Posted by arn671 View Post
I'm interested in the rev 7 sport with the carbon links and the tamale rear pod and was wondering if it can be purchased like that or would I be buying all the pieces separately? I've e-mailed speedmerchant sales but haven't heard back. Any info is appreciated.
Any Info?
arn671 is offline   Reply With Quote
Old 11-17-2011, 10:18 AM   #116
I see how it works now thank you best design I've seen so far and I'm guessing it an be adjusted faster than any other rear pod
Good job.
Old 11-17-2011, 11:54 AM   #117
303slowdown's Avatar
Trader Rating: 24 (100%+)
Good job.
It only takes about 10 seconds to adj. Its very nice.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 11-18-2011, 02:10 PM   #118
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Cool
Here are some nice close-ups of one of Pete's sweet builds.
http://www.petitrc.com/reglages/spee...011/index.html
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 11-18-2011, 02:21 PM   #119
Any Info?
You have a PM Alvin.
Old 11-19-2011, 07:33 AM   #120
where can I get the brace for the old skool front end?
gofasteddy is offline   Reply With Quote
SpeedMerchant Rev 6 Kenny L Electric On-Road 307 10-14-2014 09:29 PM
SpeedMerchant Rev 5 flameoutgarrett Electric On-Road 619 04-30-2010 01:45 PM
Speedmerchant Rev.4 Yankey Electric On-Road 1413 02-22-2008 09:24 AM
FS: Speedmerchant REV.3 W/Extras!!! boomer01 R/C Items: For Sale/Trade 7 09-03-2007 03:21 PM
