Old 09-24-2012, 08:29 AM   #391
Originally Posted by OVA View Post
Hi Greg
Over here at TZ track last year there were afew guy were mounting their servos backward in their CRC 12th and WGT..
I beleive the new CRC 12th the servo are mount backward... it seem it give more steering in the low speed ...
+1
avink007 is offline   Reply With Quote
Old 09-24-2012, 09:42 PM   #392
LonnyJ1950's Avatar
Originally Posted by avink007 View Post
I wonder if you are going in the wrong direction. When you roll out higher it takes longer to accelerate not letting the car reach its top speed. Last I asked the guys at my track with the stock rotor were rolling out between 90-92mm. Something to test...
You were right, went down to 93 and as high as 97. 93 was faster.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 09-25-2012, 12:29 AM   #393
Glad that worked better. I'm still doing some testing with mine, hopefully I'll get it all figured out by Snowbirds.
Old 09-25-2012, 12:34 AM   #394
I was playing around with my setup a lot this weekend. Added a lot more caster, thicker tube lube and heavier shock oil. Car was a lot smoother and seemed to carry more corner speed. I actually had to machine a set of the non-machined lower arms to get 10 degrees of caster, couldn't make ride height otherwise.
Old 09-25-2012, 11:03 AM   #395
AdrianM's Avatar
Whats "machined" on the old skool front end? Are they just evened up or do they have caster and camber milled into the arms?
Adrian Martinez
Old 09-25-2012, 12:11 PM   #396
4 degree of castor and 1 degree of camber machined into them
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 09-25-2012, 03:29 PM   #397
AdrianM's Avatar
How does the car run on asphalt? Did the team run at Leisure Hours for the paved Nats?
Adrian Martinez
Old 09-25-2012, 10:06 PM   #398
I actually took a set of the non machined ones and made them into 10 degree caster, 1 degree of camber. I didn't use the machined ones that came with the car.
Old 09-27-2012, 01:30 AM   #399
Why?
JoelV is offline   Reply With Quote
Old 09-27-2012, 07:35 AM   #400
Swampracer's Avatar
Trader Rating: 69 (99%+)
Default Rollout
Dose anyone have a good baseline set-up for 10.5?
What roll-out should I need for 10.5 boosted. Fairly large flowing track 100/50 ish.
What are the tires of choice for 10.5 as well. I'm use to running 17.5 Black/Yellow.
Thanks for the help. Greg G
Swampracer is offline   Reply With Quote
Old 09-27-2012, 10:33 PM   #401
Originally Posted by JoelV View Post
Why?
I've always liked the way more caster drives. I couldn't get the stock machined arms to have that much caster and still make ride height. So I had to make my own.
Old 09-30-2012, 10:06 PM   #402
The Rev 7 had a good day in Minnesota today. There were 2 of us in the class today. We qualified 1st and 2nd. I tq'ed and won, Homer had a tougher time in the main and finished 5th. Good day of club racing!
Old 10-30-2012, 04:55 PM   #403
tim fry's Avatar
Has anyone tried a CRC front end and how was it?
tim fry is offline   Reply With Quote
Old 10-30-2012, 08:22 PM   #404
Swampracer's Avatar
Default Front end
Hey Tim,
I think you might want to wait to see what's coming from Speedmerchant, as far as a new front end design. I'm guessing it's going to be worth the wait!
Sometime in the new year.
Old 10-31-2012, 05:03 PM   #405
I'm very poor at waiting, far to impatient. So I went looking for what info I could get on the new front end that the guys are developing.
I found a bit of a clue, on a picture was what I think are the new bits.
It's poor quality but appears to show a lower arm bolted to a bulkhead, R5 style, and adjustable camber via a turnbuckle. It looks like the castor may be adjustable, but can't see enough detail.
Looks like it is far easier to set than the old skool, and more adjustability.
I would love to credit the photographer, but I don't want to drop him in it!
reynard55 is offline   Reply With Quote
SpeedMerchant Rev 6 Kenny L Electric On-Road 307 10-14-2014 09:29 PM
SpeedMerchant Rev 5 flameoutgarrett Electric On-Road 619 04-30-2010 01:45 PM
Speedmerchant Rev.4 Yankey Electric On-Road 1413 02-22-2008 09:24 AM
FS: Speedmerchant REV.3 W/Extras!!! boomer01 R/C Items: For Sale/Trade 7 09-03-2007 03:21 PM
