Old 12-17-2011, 11:00 PM   #196
Suspended
Originally Posted by JamesL_71 View Post
Thanks for the info.
Am I seeing the pic above correctly? Did you true the outer few mms of your front tires down to the wheel? Effectively narrowing the front tire/contact patch?
It's just radiused a lot, for our track I leave no vertical side wall otherwise the blacks end up chunking pretty quickly along the edge. I try not to cut it down as much but I did a pretty bucky job putting a radius in.
Wes Briscoe is offline   Reply With Quote
Old 12-17-2011, 11:25 PM   #197
elee32's Avatar
Trader Rating: 18 (100%+)
Default wow!
just ran my new rev7 converted xray xII link car for the first time today. All I can say is wow....what a difference from the old side shock stock kit I was running!!! so much more forgiving and consistent when driving the car. How do you guys figure out your toe out/in on the front end of these cars? Everyone I've talked to so far says you just eyeball it but, if everything else on the car is so precise???? I used the eyeball method myself for today and the car was real good but i just feel like there should be a better way to do it
Eric Lee
elee32 is offline   Reply With Quote
Old 12-18-2011, 01:08 AM   #198
CypressMidWest's Avatar
Eric Lee
A digital caliper is your best friend. Just measure the difference in distance between the between the front wheels in front of the kingpin, then behind the kingpins.......
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 12-18-2011, 09:14 AM   #199
tim fry's Avatar
My car was awesome today. Added a bit more caster and it turned in great.
Really loving the car
tim fry is offline   Reply With Quote
Old 12-18-2011, 11:18 AM   #200
peter_robinson's Avatar
Trader Rating: 21 (100%+)
That or I use the Hudy setup station. It's expensive but you can set your toe very precisely as well as get your end points left to right exactly the same. Saves you have to go out to the track and do circles the old skool way
For orders or inquiries, email [email protected] Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
Old 12-18-2011, 03:13 PM   #201
Tim
Where are you racing? Maritime?
reynard55 is offline   Reply With Quote
Old 12-18-2011, 03:28 PM   #202
tim fry's Avatar
Originally Posted by reynard55 View Post
Tim
No West Kent not far from Maritime though and similar size. We get a couple of the quick guys come along. Just getting the hang of the car but its got plenty of potential. Are you running at Maritime?
Old 12-19-2011, 05:26 AM   #203
I'm in the Birmingham area, I do the nationals and occasionally Tamworth or Central club nights.
Old 12-19-2011, 07:57 AM   #204
tim fry's Avatar
Ah I see. I was planning on the Nationals but sadly I have work commitments this winter. Hopefully next year though.
Old 12-20-2011, 05:30 PM   #205
MrHistory's Avatar
I bought a 12r5 (not 5.1) to use its front end on my Rev7.
Will the 12r5 rear axle and hubs, shock, or any other parts fit the Rev7?
Irwin RC 1/8th Pan Car Specialists - www.irwinrc.com
SPM Competition, WRC Racing, MIP, Novarossi
MrHistory is offline   Reply With Quote
Old 12-20-2011, 11:59 PM   #206
303slowdown's Avatar
Trader Rating: 24 (100%+)
The axle will work but I think you'll need the rev7 diff hub. The shock will also work and so will the servo mounts.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 12-21-2011, 10:46 AM   #207
You will need the hyperdrive lower arm mounts, associated uses 3mm screws and the Speedmerchant is drilled for 8-32 like all other standard front ends.
The axle will work fine, the rev.7 uses the short diff side hub that I think the R5's come with.
Old 12-21-2011, 12:01 PM   #208
avs
avs's Avatar
i have a set of the hyperdrive parts i would like to get rid of. i will throw in the set of screws i cut down to make it work.
there are very few threads available in the mounts so you need to use a screw that is just the right grip length.
Tony Shimko
avs is offline   Reply With Quote
Old 12-21-2011, 03:46 PM   #209
The car is dialed out of the box. You don't need any r5 parts.
The R5 hub is similar to the old standard before "brushless centered pods" The r5.1 hub is shorter and works. Not sure if you will be able to center the rear axle and be under 172 rear width with the original r5 hub.
JoelV is offline   Reply With Quote
Old 12-21-2011, 03:55 PM   #210
KHoff7's Avatar
THIS hub
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
SpeedMerchant Rev 6 Kenny L Electric On-Road 307 10-14-2014 09:29 PM
SpeedMerchant Rev 5 flameoutgarrett Electric On-Road 619 04-30-2010 01:45 PM
Speedmerchant Rev.4 Yankey Electric On-Road 1413 02-22-2008 09:24 AM
FS: Speedmerchant REV.3 W/Extras!!! boomer01 R/C Items: For Sale/Trade 7 09-03-2007 03:21 PM
