Old 12-15-2011, 12:33 PM   #181
Yes that is what I meant by green spooge. The manufacturer doesn't label it in cst and neither do we. It really doesn't matter, It's green. It's similar to anyone running anything Josh has designed running kyosho yellow. If you don't have green spooge I'd recommend 15k-20k diff lube.
JoelV is offline   Reply With Quote
Old 12-15-2011, 04:56 PM   #182
Infinite 12th's Avatar
Originally Posted by peter_robinson View Post
The linear sides are much more forgiving. You don't have to have exactly the same preload side to side, much easier to tweak. This is why everyone uses them in high grip conditions especially (look at Vegas cars, Blackstock's 12th, Cyrul's WGT) tons of people use them.
Everyone that tries them does not go any slower, they just notice a car that is easier to drive fast.
Thanks I'm gonna give them a try
Do they mostly use the 18 or 20 and 22 in 12th?
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 12-15-2011, 10:35 PM   #183
303slowdown's Avatar
Trader Rating: 24 (100%+)
I would start with .18 and if more steering is needed do .20. Its not often you'll run the .22 but I would try them too.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 12-16-2011, 11:34 AM   #184
peter_robinson's Avatar
Trader Rating: 21 (100%+)
I am finding that on most tracks, with regular grip conditions, the difference between the springs is minimal. Their wire gauge is more noticeable on high-grip tracks, where softer becomes easier to drive without loosing steering.
I start with .18's on any new track I go to and change from there. If the grip get's insane then I almost always come back to .18's
For orders or inquiries, email [email protected] Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
Old 12-16-2011, 11:52 AM   #185
WGT setup for bumpy, Low-Med Traction.
Old 12-16-2011, 08:25 PM   #186
Suspended
Just some Rev7 porn..
.18 springs for me also seem to work best, but I am noticing on our bumpier track using the .18 spring does not allow you to run as low of ride height on the carpet, my car bottoms out much easier with the .18 than the .20, so it handles the bumps better one way, worse in others. So its a trade off.. but the car is super smooth and easy to drive.
Wes Briscoe is offline   Reply With Quote
Old 12-17-2011, 04:51 AM   #187
Blue Screw's Avatar
Send a message via AIM to Blue Screw
Bruce,
Im still waiting on the lower rear graphite piece for the pod setup.. Remember the mis comunication we hadabout what chassis.. i had the inline or reg... I did recieve the parts from team tamale though... and i must say u guys put together quite a work of art between the 2 of you...
Angelo DAlessandro
AE~REEDY~LRP~JCONCEPTS~NOVAROSSI~HUDY~IRS~KALGUARD ~ABSOULUTE HOBBYZ~GRAVITY-RC~TnT CUSTOM GRAPHICS
NITRO ONROAD
XRAY~RCAMERICA~HUDY~SRC~MURNAN MODS
Blue Screw is offline   Reply With Quote
Old 12-17-2011, 09:12 AM   #188
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Nice ride Wes
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-17-2011, 09:39 AM   #189
b_recliner's Avatar
Trader Rating: 22 (100%+)
Wes and Peter...those cars are inspiring! What servo saver are you fellows using that allow the servo to be taped flat to the chassis like that, or is something under the servo to raise it up a bit for clearance. When I investigated it on my car, the rounded, bottom part of the servo saver extended past the base of the servo and prevented me from laying it down. Thank you for your time gents.
Tracks: Richfield Raceway, LCRC, DRP
Current Cars: Xray t4 '14, Schumacher Cougar KF, Schumacher Mi5, Losi 22 2.0, Losi 8ight E 3.0
b_recliner is offline   Reply With Quote
Old 12-17-2011, 10:11 AM   #190
I remember looking at a pic of your Rev7 from the "best/cleanest electronics install" thread and thinking how clean it looked. I went back to find it and noticed you were previously runny a Tekin.
How do you like the LRP compared to the Tekin? Any reason why you switched?
Btw, car looks great. Inspiring me to trade in my 12R5.1 for a Speed Merchant
Speedmerchant Rev.7 Sport
JamesL_71 is offline   Reply With Quote
Old 12-17-2011, 01:44 PM   #191
Wes
I see a different centre shock location on your car, moved forward .250 or so
Development parts?
reynard55 is offline   Reply With Quote
Old 12-17-2011, 03:03 PM   #192
Suspended
The servo is cut out to allow the servo saver to protrude "through" the chassis but does not dip below the chassis itself. All Speedmerchant chassis are cut like this, on something like a CRC you may need to cut a hole in the chassis to run a flat servo.
Old 12-17-2011, 03:09 PM   #193
What about this esc question Wes?
Old 12-17-2011, 03:09 PM   #194
Suspended
I did not like the compromise in weight distribution from right to left that running a receiver pack or booster caused, the car was a touch heavier on the battery side always and I could not move my transponder over to adjust for that.
The LRP is easier to use, no booster (which had failed on me twice) and no receiver pack. For blinky it seems to work just fine, and I think with the newest firmware it feels like it is going to be good enough for boosted - but I have not ran it yet in boost - bench testing though it sounds pretty fast. Also with this setup the car is now 731-736 grams (depending on scale.)
Performance wise I like the feel of the LRP. It feels much smoother than the Tekin, and in blinky classes feels more ligitament than running the Tekin, IMO.
Old 12-17-2011, 10:10 PM   #195
Thanks for the info.
Am I seeing the pic above correctly? Did you true the outer few mms of your front tires down to the wheel? Effectively narrowing the front tire/contact patch?
SpeedMerchant Rev 6 Kenny L Electric On-Road 307 10-14-2014 09:29 PM
SpeedMerchant Rev 5 flameoutgarrett Electric On-Road 619 04-30-2010 01:45 PM
Speedmerchant Rev.4 Yankey Electric On-Road 1413 02-22-2008 09:24 AM
FS: Speedmerchant REV.3 W/Extras!!! boomer01 R/C Items: For Sale/Trade 7 09-03-2007 03:21 PM
