Old 11-10-2004, 02:02 AM   #16
mashimaro's Avatar
btw, it reminds me of this buggy a lil bit
it's called Durango
mashimaro is offline   Reply With Quote
Old 11-10-2004, 02:03 AM   #17
mashimaro's Avatar
here's another pic
Old 11-10-2004, 02:06 AM   #18
BerNardLee's Avatar
Originally posted by pink pac man
wierd......the servo is in the back of the car
And it need a very long linking rod for the steering thus added weight on it.
BerNardLee is offline   Reply With Quote
Old 11-10-2004, 02:56 AM   #19
Cole Trickle's Avatar
Originally posted by mashimaro
Look at KX-One, battery is mounted above the belt, not good either
True. But batteries wieghs way more than a belt or shaft.
Having a shaft and the diffs above the batts, will raise CG. But since the batts are way more heavy than a shaft and the diffs, it might still be an advantage.
One thing to wonder about: Why have nobody made a shaft car with the batts in the middle and the shaft besides the battes? Something inspired by the JRX-S...
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 11-10-2004, 03:15 AM   #20
BerNardLee's Avatar
It may due to the front and rear diff also need to be raised, and the bulk head as well.
Old 11-10-2004, 03:19 AM   #21
Thraex's Avatar
In my opinion there are more options.
Why don't you make the mainshaft out of dogbone/CVD style shafts, so you can make the mainshaft in an angle.
This way you can build the mainshaft "around" the batteries.
And like Cole said, why not mount the shaft(s) on one side of the car.
I think the batteries should be in the center as close as possible, 'cause it's about the heaviest component in the whole car.
The disadvantage will be that the drivetrain won't be so smooth anymore. But I think that's better than putting al that weight (the batteries) on one side of the car.
Thraex is offline   Reply With Quote
Old 11-10-2004, 03:25 AM   #22
BerNardLee's Avatar
Another idea is to split the battery into 3 each like some belt car is using.
Old 11-10-2004, 03:37 AM   #23
Thraex's Avatar
Just another thing... how do you want to mount the motor?!
I think the only opinion is to mount it parralel with the mainshaft.
So that means you have to mount it on one side,
and to comprimise you should mount the batteries on the ohter side.
I don't see a way to place the motor in the center of the car.
If you do, the motor has to be at right angles to the mainshaft, and I don't see that happen.
Another solution is to mount the mainshaft above the motor, but I think that's just a bit to radical.
Old 11-10-2004, 04:19 AM   #24
BerNardLee's Avatar
Motor will be mounted the same as Pro4, servo+ESC+receiver will be another side of the motor.
Old 11-10-2004, 04:21 AM   #25
AdR|aN's Avatar
Send a message via ICQ to AdR|aN
Yo Bro. Meet up later at Harley's Place?
AdR|aN is offline   Reply With Quote
Old 11-10-2004, 05:16 AM   #26
BerNardLee's Avatar
having lockup tonite, let me try first.
let you know later.
Old 11-10-2004, 06:16 AM   #27
kufman's Avatar
I think the Durango layout cold work well for a sedan. Finding space for electronics could be a pain.
Brushes? We don't need no stinking brushes!!!
kufman is offline   Reply With Quote
Buggy Center Drive shaft stonely0 Electric Off-Road 2 10-02-2006 03:04 PM
Belt Drive versus Shaft Drive SUNA Nitro On-Road 20 03-28-2006 09:04 PM
Belt drive versus shaft drive...pros and cons of each? AttackDonut Rookie Zone 21 01-02-2005 05:23 PM
Belt drive or Shaft Drive tc3wood Electric On-Road 4 12-03-2004 07:57 AM
TMAXX MIP Center Drive Shaft Nitro_Crash R/C Items: For Sale/Trade 2 08-04-2003 01:15 PM
