Tamiya TB-02 or TA-04S ? or other ??? >
Old 11-09-2004, 09:24 PM
Default Tamiya TB-02 or TA-04S ? or other ???
I'm trying to pick between these two kits since they are about the same price. I'm a new to the sport and will probably hit a couple of things on the way....
If there are other options, please chime in.
Thanks,
Joe
ptjoe is offline
Old 11-09-2004, 09:38 PM
Korey Harbke's Avatar
I would probably get the TB-02. The shaft drive gives it some better accelleration, plus it's a newer design that is based off the renound TB Evo III.
-Korey
Korey Harbke is offline
Old 11-09-2004, 10:15 PM
RCGaryK's Avatar
The 04S is a very sturdy and durable design, but it also lacks a lot of features that the TB comes with. The biggest difference is that the S comes with Gear Differentials, where the TB comes with Ball Diffs. For a beginner, Gear diffs are really easy because you just build them and run. You don't need to adjust them like a Ball Diff. But the car won't handle as well as one with ball diffs. The one thing about the TB 02 (and the Evo 3 to some point) is that the front gears can take a pounding and get pretty beat up. It's worse when running a front one-way than a front diff though. I would actually see if you could find a good deal on an 04R, 04R Tuned, or 04 TRF chassis over either.
RCGaryK is offline
Old 11-10-2004, 02:24 AM
mashimaro's Avatar
Are you buying them new or 2nd hand? becasue if u r getting them new, may be try n 2nd hand 04R for a cheap price. Much much better than both of them
mashimaro is offline
Old 11-10-2004, 06:58 AM
Thanks for the info. Second hand is preferred since cash is a little tight. I would like something newer than my Xpress to start racing. No one races Tamiya locally (mostly Xray, AE). Those are great cars, but I like to be different.
I'll keep my eyes out for a 04 variant.
Keep the info flowing....
ptjoe is offline
Old 11-10-2004, 07:16 AM
todd8603's Avatar
I currently have an 04 Pro with both ball diffs with lightweight outdrives and optional one way for further down the road. THis car has been extremely durable with top and bottom carbon reinforced graphite. This car is excellent to drive and because it is older many people have had it and can help set it up in a fairly neutral starting point. From there, only subtle changes are needed to make it ride well Even the Tamiya site has a setup sheet to start off with that can really help out.
As for the TB02(AKA Evo3 with Tub chassis), I finish alot more races with my o4 than the ones driving Tb02 do due to the diff troubles mentioned in previous posts. IT is an excellent chassis for those who have rare minimal crashes. The diffs seem to pay the price in wall crashes.
The 04 is a little havier than some newer models but it is VERY durable. Want evidence, go to LHS and compare the control arms of TC3 to those of the 04. Durability will be VERY evident. As a relative nebie myself, I will say that durability is more important at this stage than blinding speed.
If you want to see how my o4 looks, I can pics. Not really thinking of selling but you might like to see one built.
todd8603 is offline
Old 11-10-2004, 08:55 AM
Todd,
Any pics would be great. My email address is [email protected] if you'd like to email them.
Thanks!
ptjoe is offline
Old 11-10-2004, 02:57 PM
FlyinGT's Avatar
if ur looking for a TA04 R Tuned chassis ...
hong kong have them for bout $200us to $215us
which i believe is a great price ..!!
just a suggestion if u have the means to buy OS ..
the fact it is new ..is wat i like best ...
FlyinGT is offline
Old 11-10-2004, 08:38 PM
Can you recommend a HK website that has the kit?
ptjoe is offline
Old 11-10-2004, 09:34 PM
FlyinGT's Avatar
http://shopping.rcmodel.com.hk/
had them instock .. but i don't know of any at the moment that have them anymore .. they were a limited edition release ..!!
i fu are lucky u may find one ..
i brought my TA04 from STELLAMODELS on Ebay check that out
or jst buy a TA04 R ....
FlyinGT is offline
Old 11-10-2004, 10:54 PM
Thanks! I'll check it out.
ptjoe is offline
