Old 09-03-2011, 08:12 AM   #16
I know one of the clubs locally used mats from a horse barn and cut them to shape and size. They are probably UHMW material but they were used. The mats themselves are ridiculously expensive new.
There is a recycled rubber product that I am curious if anyone has tried or has an opinion about it's suitability:
It sold as Recycled Rubber Flooring and is made from recycled truck tires.
About $100 for a 4'x10' roll. Still not cheap, but 1/4 of the price of UHMW. Should be heavy enough to stay in place. Only 3/8" thick, but may still serve its purpose.
Any suggestions?
tracks75 is offline   Reply With Quote
Old 09-03-2011, 08:29 AM   #17
locked's Avatar
Here are some of those horse stall mats referred to above. It took the FastCats crew a very long time to power sand the bevels on all the edges. It is by far the most forgiving track I've raced on. If you cut a corner, it usually upsets the car just enough to lose a little time, but won't send you flying into a wall.
The mats are around 3/4" thick. The big ones are HEAVY.
+ YouTube Video
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
Last edited by locked; 09-03-2011 at 09:58 AM. Reason: Changed video - Better track layout
locked is offline   Reply With Quote
Old 09-03-2011, 09:18 AM   #18
Suspended
These horse stall mats are perfect if painted red/white , and velcroed to the ground ! The only thing left is the flexible link barriers between them, and foam backed outside track walls with lots of space(at least 12feet) behind them !!! That space behind the track walls is very important in case of a high speed accident, it will give the cars some tumble room outside of the track !!!
bertrandsv87 is offline   Reply With Quote
Old 09-03-2011, 09:31 AM   #19
locked's Avatar
Yeah, they are very heavy rubber, so even a 1:1 scale car would not be able to slide them around easily. I've hit an unbeveled side a couple of times. Trust me, those mats don't move.
Dave Locke
Old 09-03-2011, 09:42 AM   #20
Suspended
Good, I guess if you make each corner from a heavy enough mat you won't have to use velcro !!!
Old 09-03-2011, 10:45 AM   #21
For parking lot we used a heavy black hose rubber pipe about 1 3/4 inch high, they were fairly heavy to carry around but we had some good lengh to make the track with, then there is the fire hose filled with water or sand.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 09-10-2011, 09:31 PM   #22
Trader Rating: 14 (100%+)
Originally Posted by BrodieMan View Post
Are the middle section of the boards is something like Styrofoam to absorb impact and reduce breakage. Looks like a great setup.
On the track construction theme
What asphalt sealer gives the best traction.
Nope, I've raced at this track and the boards are all made from 2x4's and flappers, no styrofoam.
Speedpassion : Speedpower : East Coast Bodies
thunderbt3 is offline   Reply With Quote
Old 09-11-2011, 12:17 AM   #23
CR0SS's Avatar
For curbing I was thinking you could take 3/4" plywood and cut trim it down like those guys did with the floor mats. It would be much easier to trim and bevel the edges. With a good bevel the cars would roll onto them and not push them out of the way. Then you could just paint it or even use spray on bedliner to coat the plywood.
This still only works in large areas where you have the room. Smaller carpet I think the 2x4s and plastic work well.
You know the guy that beat you at the last race? It was not because of his car, or motor, or battery, it is because he was a better driver. Now go practice so you can beat him.
Visit my Youtube channel for HD R/C videos. http://www.youtube.com/user/DHCross1
CR0SS is offline   Reply With Quote
Home track construction questions... prestondan Electric Off-Road 295 01-30-2014 08:27 AM
Track Build Question KWT-NITRO Nitro On-Road 15 12-26-2009 10:14 AM
Track Construction has started at Aeros digefxgrp Northwest Racers 159 04-07-2007 02:45 PM
