grinding only while turing >
Old 08-30-2011, 10:53 AM
theatriks's Avatar
Default grinding only while turing
hey guys i got a problem in my front end im running a spool upfront and there is this terrible grinding noise upfront only when i turn left or rite all the way i took the front end apart checked out the spool and everything is fine and nothing is rubbing so does anybody have an idea of what it could be? im running a ta-06....and it grinds more with the tires on then with them off?
theatriks is offline
Old 08-30-2011, 11:05 AM
Smile
If you have cvd joints in the front, you are experiencing Chatter ! The only way to eliminate the problem is to switch from cvd drives to either Lcd drives ,ecs drives, or Dcj drives.....
bertrandsv87 is offline
Old 08-30-2011, 11:10 AM
theatriks's Avatar
really? it wasnt doing that before ? and can i not just replace that with original equipment or will that happen again?
Old 08-30-2011, 11:42 AM
Xpress's Avatar
It will happen again with standard u-joints/cvd's.
Xpress is offline
Old 08-30-2011, 11:59 AM
maybe if you reduce the turns on your radio it might help
olly986 is offline
Old 08-30-2011, 12:02 PM
theatriks's Avatar
Ok who sells the best shafts that I can buy where I won't have this problem?
Old 08-30-2011, 12:04 PM
Monkeys punk's Avatar
If you replace the worn parts it will calm the chatter down but not stop it.That is all i do and its never really bothered me. I do how ever turn my steering travel down to the point that is is actually usable and this is right before the full lock so its not an issue. If you run it round the track and turn it down till you actually notice a difference in your steering. You will be surprised how far it goes before you notice any change.
Hope this helps mate. its how i set mine up and i am happy with it.
Monkeys punk is offline
Old 08-30-2011, 01:37 PM
theatriks's Avatar
well i never had this problem with my ta-05 now with a newer model the ta-06 im having this problem....even with my epa down to 50 on both sides it still does it so im looking for replacements anybody know of good replacement shafts
Old 08-30-2011, 09:27 PM
Foxxrocket's Avatar
It's one of the downsides to having a spool. I just live with it.
Foxxrocket is offline
