Mario Kart Thunder Tiger KT8 >
Old 08-30-2011, 09:02 AM
Default Mario Kart Thunder Tiger KT8
So ever since i saw one of these rc go-karts I've wanted to do this. Is it competitive in any way at all? Of course not, but it's fun. I'll continue to update as the build evolves but this is what I have so far.
I'm running a Gens Ace battery from Hobby Partz. man I love these things! I want to try the bigger 1800mAh battery but the run time on the 1550mAh has been fine so I havent bothered.
You have to mod this car straight out of the box. When the wheel is turn full lock the wheel rubs on the body and the lower arm. A dremel and endpoints will fix this and even with endpoints it still turns well but it could be better. You may be able to get away with not adjusting the arms but if you don't set the endpoints your car will understeer horribly.
The suspension also comes with tons of positive camber in the front! I haven't come up with a solution to this yet but I'm working on it.
I dont have a picture but i did fill the sealed rear diff with Associated 10K oil to help prevent too much understeer.
Next I modified the seat for the Toad plush doll I got at the local Fry's Electronics.
Finally I mounted the doll! I will be painting the body in the style of Toad's kart in Mario Kart Wii but I need to figure out how I want to accomplish that.
JJBTEXAS is offline
Old 08-30-2011, 09:42 AM
Kwikvdub's Avatar
Trader Rating: 92 (100%+)
Thumbs up
Looks like they run pretty nice: http://www.youtube.com/watch?v=4RG_cUEg7_A
Looks like Mario needs a neck strap thou.....
Kwikvdub is offline
Old 08-30-2011, 11:02 AM
That's sweet, Toad/s head is pretty sturdy so he doesnt do that quite as much. Ill try to get a video as soon as i get the foam tires i ordered.
JJBTEXAS is offline
Old 09-02-2011, 05:44 PM
Ok got the new tires and this thing is sick! they are a bit bigger but i feel like they are more to scale for a "mario kart" and they grip amazingly. The kart now pops wheelies! Had to trim the "body" a little to fit the rear tires but it wasn't a problem at all. The front tires even have better clearance than the stock tires!
For the fron I used RC18R foams from TheToyz.com and in the Rear I used Associated RC18T foams.
JJBTEXAS is offline
Old 09-02-2011, 07:11 PM
texastc's Avatar
several of the guys that race at MIkes hobbies in Dallas have these. They had a class for a bit but it fizzled. They are quick. Did a couple of laps in one
texastc is offline
