Old 08-28-2011, 10:44 PM   #1
@Art_Mighty's Avatar
Default Rear One Way?
Has anyone been able to make a One Way Diff work in the rear? If so what happens, is it worth the experiment?
RC.A. - Tamiya Chapter (so many shinny blue parts..) O_o
Sponsored By - http://enginesbyotto.com/ & my wallet (mostly my wallet actually...)
ALL IS LOST
@Art_Mighty is offline   Reply With Quote
Old 08-29-2011, 12:41 AM   #2
WC
WC's Avatar
Trader Rating: 28 (100%+)
usually nothing gained... having only frontwheel brakes, it'll plough on ahead
what car?
TA05 has both centre & diff oneways; to use diff oneway at rear
you'll need one that's oneway in the opposite rotation to the front.
AFAIK nobody makes such a beast.
With a bit of DIY ingenuity you could mount centre oneway pulley
to run the rear belt...
Some shaft cars like TB02/3 & TBevoIII/IV/5 can be set to run either way
so you can make a 'front' oneway to work fine at the back (motor reversed).
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 08-29-2011, 04:51 AM   #3
I tried balldiff front and one-way rear on a Ta05. Weird handling, cannot explain it, but will never try that setup again
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 08-29-2011, 03:51 PM   #4
That was my smile for the day right there...
ALL IS LOST
Old 08-29-2011, 08:48 PM   #5
First off, if you are using a one-way designed for the front of a car in the rear... you better make sure the front and rear diffs are oriented/offset to the same side. Otherwise you will end up with the rear not being driven at all.
Secondly... the the handling traits will be peculiar to say the least. The car will be affected during on-power application and during braking.
On-power it will be similar to a 1/8th on-road car, ie: solid rear axle, which gives you lots of on-throttle steering. However, if you are using a regular ball or gear diff in the front, you won't get the pull/bite out of the corner that the front wheels provide with most 1/8ths(assuming the front/rear drive ratios are equal or overdriven). I suspect you will end up with a very tail happy car. If you can get it drivable, you will probably need to slide the car around a fair bit to turn a quick lap.
The worst handling trait, I suspect, will be under braking. A one-way rear will give you no rear brakes.... ie: 100% front brake bias. With the inertia that the rear of the car will be carrying, if you brake in anything but the straightest of lines when approaching a corner, you will be out in the weeds, ass-end out.
Basically... it is not a good idea. If you want to experiment you could try a solid axle/spool in the rear. This would give you the desired(if you can call it that) traits of a rear one-way, without the negative braking effects.
JamesL_71 is offline   Reply With Quote
Old 08-29-2011, 08:59 PM   #6
skypilot's Avatar
Trader Rating: 14 (100%+)
its not really that big a deal, remove the bearings, turn them around and re insert them, no need to go changing the whole car around, as stated you will only have front brakes, but depending on what class your running maybe you don't even use brakes. I have seen guys use dual one ways on a mini and it got around the corner pretty damn good, no brakes but awesome rotation.
semi retired..
skypilot is offline   Reply With Quote
Old 09-01-2011, 01:23 AM   #7
prob spin out all the time? i dunno give it a try man!
Mike-Xray is offline   Reply With Quote
rear one way?? odawg315 Electric On-Road 18 04-11-2005 02:18 PM
One-way HK Racing Joe Electric On-Road 36 01-28-2005 08:55 AM
Why no one-way or spool at rear? Aku-Man Electric On-Road 6 04-18-2004 05:56 AM
