Old 08-25-2011, 07:28 PM   #1
Default Winter Racing
Dear all,
Just a quick question on racing during winter in US and Europe, is that majority of the racing is indoor carpet track? What tires are the most popular choices?
Cheers
Warbird is offline   Reply With Quote
Old 08-25-2011, 09:45 PM   #2
BrodieMan's Avatar
Spec tires seem to be very common at most tracks so I would check with the club you plan on racing at. From what I've read on RCTECH, Sorex have become very popular. Jaco's have a great reputation but I can never find them in stock. I've been using Muchmore Absolute 32* as the spec tire for my club with great results, no broken rims or any failures at all plus they are always in stock at Tower. Apparently Muchmore rims are weak but I have not had any evidence of that. Sweeps have apparently increased greatly in quality. Solaris is another winner.
Hope that helps a bit
Mark Richardson
Kawartha Radio Controlled Racers
Lakefield Hobby & Game. ExtremeRCforum
Schumacher Mi4cx CRC Gen-X 10 LE
BrodieMan is offline   Reply With Quote
Old 08-28-2011, 09:26 PM   #3
Thank you for information, much appreciated!
Old 08-28-2011, 11:25 PM   #4
BrodieMan's Avatar
I raced at a track with wood barriers today and my Muchmores fell apart from a couple minor wall taps. On my track they hold up fine but we have really flexible vinyl barriers. They have good traction though. Tried out some of the new Schumachers/Sorex XG-32 BM today and held up to a few wall taps just fine but they are expensive. I'm ordering some Sweep Real Blues to test out for a spec tire, been hearing good things and the price is great.
From everyone I talk to, Jaco Blues are awesome but finding them seems to be impossible.
HPI Gumballs are garbage. I gave them away after one meet.
Mark Richardson
Old 08-31-2011, 07:31 AM   #5
Thanks, so for carpet surface the lower temp rating tires are the go? If I assume that is because it is indoor and carpet dose not retain heat as much as asphalt?
It that case a thinner insert is also a better choice for carpet racing?
Cheers
Old 08-31-2011, 08:13 AM   #6
BrodieMan's Avatar
I've only been running on-road for just under a year so I am not overly knowledgeable on tires, especially inserts as I buy pre-mounts. On carpet you want harder compound tires 30 - 36* as the high traction from the abrasive surface heats the tires up really quick and keeps them hot. Tires for hot weather asphalt & carpet are usually around the same "degree".
After lots of research I'm going with Sweep Racing Real Blues as my clubs Spec Tire. Jilles Groskamp has just joined the team so if Sweep tires have Jilles endorsement, the should work just fine for my little club.
Mark Richardson
Old 08-31-2011, 09:40 AM   #7
Regional Moderator
CarbonJoe's Avatar
Sweep QTS-32 True Blue tires were the spec tires at the Halloween Classic, Indoor Champs, and Midwest Grand Slam last year, and look to be the same this year. Most of the local racers have converted to them from Jacos and Solaris.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 09-01-2011, 07:51 AM   #8
tc3team's Avatar
I like the sorex 28 indoors, but really it depends on what tyre the series decides on.
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 09-01-2011, 10:07 AM   #9
Buckaroo's Avatar
Indoor racing on carpet at my track. Although some guys are running things like Jaco Blues (when available), Solaris softs/mediums, and Muchmore 24/28, the overwhelming favorite is Sorex 24s. Paragon is our tire treatment of choice.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 09-01-2011, 07:53 PM   #10
Great thanks, so more towards a softer compound, right? So it will generate heat a lot faster, and it is a good carpet choice, right?
Old 09-01-2011, 08:10 PM   #11
HarryLeach's Avatar
Send a message via AIM to HarryLeach
There's a bit more to it.
Age of the carpet, average turnout on race days, traction compound used, temperature of the track, all those factor in to the ideal tire compound.
If the track gets real cold, a soft tire will have more grip.
If the track has 40+ guys every race day, you might need a harder tire to free the car up for corner speed.
If the carpet is fairly new, again, higher traction, so a harder tire will probably carry more corner speed.
If there's predominantly only one traction compound in use, traction can raise during the day. If there's a mix, then there's a chance nobody will have traction.
Best bet is to ask the guys you're going to be racing with what the tires of choice and/or spec tire is.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 09-02-2011, 09:24 AM   #12
theatriks's Avatar
you use muchmore 32s for carpet....i thought the 24s were suited more for carpet?
theatriks is offline   Reply With Quote
Old 09-02-2011, 09:32 AM   #13
HarryLeach's Avatar
Usually when a track specs a tire, they go with a harder tire for longer wear, thus fewer sets required to finish a season.
With open tires, you could just change compounds through the day to maintain the same handling and speed.
With a spec tire, you have to stay on top of your chassis adjustments to stay [or get] fast.
Old 09-02-2011, 09:36 AM   #14
theatriks's Avatar
what is a spec tire ....at my club we can use any tire we want except for tcs sooo i dont know what u mean by that
Old 09-02-2011, 09:46 AM   #15
HarryLeach's Avatar
Spec tire means either the track, or the club has decided that everyone is only allowed to use one tire brand and compound.
If you can use any tire you want [except TCS], your club has an OPEN tire rule, no restrictions.
*Winter racing? Looking for input!* Zdiddy MSRA (Memphis, TN) 17 08-25-2010 10:14 AM
Winter Racing, Fargo North Dakota Cain Minnesota and North/South Dakota Racing 29 12-02-2006 07:55 AM
Winter Racing in Fargo Cain Minnesota and North/South Dakota Racing 18 12-22-2005 07:15 AM
Tchr Winter Racing!!!! Steve Nelson Minnesota and North/South Dakota Racing 62 03-15-2005 03:57 AM
