tire gluing
Old 11-06-2004, 04:32 PM
Default tire gluing
For 1/10th on-road touring cars, do people usually drill vent holes in their rims? Thanks for any help in advance.
scotwithonly1t is offline
Old 11-06-2004, 07:11 PM
rcinsight's Avatar
Are you still asking about tire glue?
Ventilation concerns should be addressed elsewhere like cutting the body out behind the rear wheels and Dremeling the battery slots and motor cavity. Use your imagination.
Velocity type wheels have the lowest drag coefficiency of all the wheel designs.
Spokes are like paddle wheels and create drag.
That's why you see Electric cars and Hybrids with flat faced wheels.
Drilling the wheels can also ruin the trueness of the assemble and waste your money.
Buy a fancy wheel if your just after the look and then go out and have some fun.
rcinsight is offline
Old 11-06-2004, 07:50 PM
onebeatuptc3's Avatar
the only reason i would say put a hole in the wheel is because all the take off tires and preassembled tires and wheels come with a hole drilled in the wheel.
onebeatuptc3 is offline
Old 11-06-2004, 07:52 PM
i drilled my dish wheels, what the porpuse of cutting out the body behind the rear wheels? and how much to cut?
kh15 is offline
Old 11-06-2004, 07:55 PM
its bascally cutting the whole rear part of the body off where the sides meet the back. What is supposedly does is remove any drag from air that swirls up from the ground and gets trapped there.
Old 11-06-2004, 07:57 PM
rcinsight's Avatar
True for the most part.
I heard it's really there as an access hole for whatever reason on certain models.
Then the balance is off and then it'll create a shimmy and then yada yada.
Old 11-07-2004, 10:45 AM
Speedie's Avatar
I believe he was talking about small vent holes inside of the rims, like the premounts. At least I hope he was. If they are not there definately drill at least one. Two would be better if rules allow. Without the vent holes the tires will not work properly.
Speedie is offline
Old 11-07-2004, 11:37 AM
KoE
KoE's Avatar
our track temp during high noon is often searing hot so lots of drivers drill multiple holes. they help saving the tires a bit
KoE is offline
Old 11-07-2004, 12:25 PM
rcinsight's Avatar
I drive in Michigan in the winter so sometimes we practice without heat until it kicks in and run softer foams than the purple/plaid set up.
Never saw holes in TC3 wheels but, understand the method to the madness.
Old 11-07-2004, 12:35 PM
Speedie's Avatar
Were talking about rubber tires not foams. They are not to vent heat it is so that the air is not trapped inside the tire and make the tire bouncy. It lets the insert do its job not the air inside.
Speedie is offline
