Old 02-13-2012, 03:58 PM   #46
Default OP12C
See everyone at the Roar Nationals in Dallas next month.
Steve Dunn
Indianapolis, IN
sdunnmcp is offline   Reply With Quote
Old 02-13-2012, 04:39 PM   #47
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Good to hear Steve!
Old 02-15-2012, 08:04 AM   #48
chicky03's Avatar
Send a message via AIM to chicky03
Default Website Updated!
The website is updated with Snowbirds info, setups and new OP12C Black Edition! www.onpointracing.com
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 02-29-2012, 12:18 PM   #49
Robert_K's Avatar
Like this Black edition
Regards Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 02-29-2012, 01:09 PM   #50
chicky03's Avatar
Regards Robert
Looks Sweet!!!
Old 03-01-2012, 05:53 AM   #51
avs
avs's Avatar
Regards Robert
looks good. what bits did you use to finish the front end with?
those ball cups and blacked out turnbuckles look like nice pieces (in any color)
Tony Shimko
avs is offline   Reply With Quote
Old 03-01-2012, 07:28 AM   #52
Robert_K's Avatar
BallCups are Associated (TC6) black when you buy them ;-)
Turnbuckels are Limited Edition Tamiya's Blacks. (both the Camber turnbuckels as the Steering Turnbuckels). Nothing is really made "black" except for the wires.
Regards Robert
Old 03-01-2012, 08:52 AM   #53
Absolutely wicked looking car! Great job with the wiring and electronics layout, too. Love it
JamesL_71 is offline   Reply With Quote
Old 03-01-2012, 05:36 PM   #54
darnold's Avatar
Default OP12
Rob that car looks absolutely awesome!!! What are you using for the top hinge pins, and are the Yokomo turnbuckles titanium? Just curious, although it won't matter because when I get mine I won't be changing mine one bit...
Team Top Racing USA,Team MaClan ESC, Pro One Tires, Hot Race Tires
darnold is offline   Reply With Quote
Old 03-02-2012, 02:54 AM   #55
Robert_K's Avatar
Thanks!
The Nitride Coated hing Pins are Hotbodies Cyclone 12 (bit to long so you need to grind them)
All Turnbuckels are Tamiya Aluminium ones!
Regards Robert
Old 04-20-2012, 04:00 PM   #56
samnelso's Avatar
You guys that use the HB shock, how well does the shock shaft fit into the spring retainer? The hole in my retainer is way oversized for the shaft and therefore the shaft is cocked in the retainer, making the whole shock look bent from the side view. Just wondering if that's common or if I got a bad one.
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 04-20-2012, 04:50 PM   #57
I have built a number of the HB center shocks and never had this happen... Sounds like you got a bad one.
Old 12-14-2012, 09:21 AM   #58
Default OP12C.1
On-Point Racing is proud to release their second generation 12th scale conversion, the OP12C.1. Already it has won the Super Stock class at the US Indoor Champs last month driven by designer/owner Paul Ciccarello. We believe the changes made in chassis flex and shock position have made the car generate higher corner speeds with out giving up driveability. Available now!
New On-Point OP12C-2012-12-13_14-08-36_588.jpg   New On-Point OP12C-paul-champs-13.5.jpg
On-Point Racing [email protected]
On-Point Racing is offline   Reply With Quote
Old 12-14-2012, 09:29 PM   #59
Nice work Paul. Always glad to see advancements in 12th.
Old 12-29-2012, 09:06 AM   #60
Robert_K's Avatar
On-Point Racing is now on facebook! The page is still under construction, but give it a like!
https://www.facebook.com/OnPointRacing
Regards Robert
On-Point Racing On-Point Racing Team and Company Discussions 402 12-04-2015 03:31 PM
