Old 11-04-2011, 06:23 PM   #31
Infinite 12th's Avatar
Can a chicky car pic come forth
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 11-15-2011, 07:23 PM   #32
chicky03's Avatar
Send a message via AIM to chicky03
Default On-Point OP12C Takes Top 2 spots at EPS race #1
Markus Mobers and Joey Sorber finished 1,2 in modified 12th at EPS race #1
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 11-15-2011, 09:11 PM   #33
iPearl's Avatar
Trader Rating: 96 (100%+)
Send a message via AIM to iPearl Send a message via MSN to iPearl
HIgh dollar Pancar ? or on the budget ?
Design Of Things !!!
iPearl is offline   Reply With Quote
Old 11-18-2011, 03:37 PM   #34
avs
avs's Avatar
Originally Posted by chicky03 View Post
Hey Guys!
Just a little update on the Halloween Race.
We had the most cars in the Mod A-main. 4 Cars qualifying 3,4,5 and 7th, Finishing 2,4,8 and 9th. I finished about 3 feet behind the leader. It was an exciting race!
For 13.5 I qualified and finished second Steve Dunn qualified and finished 10th.
Since the car is a conversion we have had a lot of requests to use a more universal color to match other brand components. We chose BLACK. Orange will still be available! Black be available in a few weeks!. I'll have some pictures on line in a few days.
Also the website is coming along, we are super happy with it!
Next stop, US Indoor Champs where we will be the sponsor for the Mod 12th scale class.
regarding the all important color coordination challenge:
Ss there a cost effective (read cheap) method to make the blue 12R5 front end parts black, grey, silver or ? orange would be nice too but i expect that requires some professional service. the 2 parts i am referring to are the aluminum lower arm inserts and the titanium camber links
Tony Shimko
avs is offline   Reply With Quote
Old 11-18-2011, 07:37 PM   #35
chicky03's Avatar
I'm not exactly sure what you are asking but I think you want to know if this is a cheap car? It is good quality and not very cheap money wise but many think it a reasonable price for what you get.
To make it any other color than silver requires to be sent to an anodizer. Usually this is a lot charge of $50-70 almost as many parts as you like. If you want to make it silver there is a chemical called Zep Crystal Drain cleaner from Home Depot that will get the job done. It is a seriously dangerous chemical in my opinion but it will take the coating off of anything on the planet. I recommend you use gloves and do it outside because it makes some seriously dangerous vapor.
To use it:
Have a small container of water. pour the Zep into it and stir, keep adding until it starts to bubble and smoke. The put the part in there for only seconds at a time until the anodizing comes off the part. You will want to have a separate tub of clean water to soak it in after the anodizing comes off. I would try to scrub the part in clean water shortly after or it will corrode. If you leave it in the Zep too long the aluminum will wear away and the part will become too small to use anymore.
Or you can just buy the OP parts already black and be a much healthier individual in the end
We sell R5 blocks in black with black inserts and I have a few orange inserts that will work with the std R5 blocks laying around.
Old 12-03-2011, 01:47 PM   #36
chicky03's Avatar
Default New Website!!!
Old 12-03-2011, 01:55 PM   #37
Our new website is up and running!!! http://www.onpointracing.com
Products, info and results from the Indoor Champs!!
On-Point Racing [email protected]
On-Point Racing is offline   Reply With Quote
Old 12-03-2011, 05:02 PM   #38
corallyman's Avatar
Trader Rating: 99 (100%+)
Had a look around at your new website, very nice indeed. Lots of pictures and information on the products. Great job!
I think you would really like the On Point parts and Car kits. They are very nicely developed and perform like you'd want. The fit and finish is top quality. I bought the On Point Serpent Link car last year, then recently purchased the new conversion so I now have the inline version as well. Both kits are very nice and they look awesome, and best of all, they perform great!
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 12-21-2011, 11:40 AM   #39
Bump ! ! !
sdunnmcp is offline   Reply With Quote
Old 12-21-2011, 10:13 PM   #40
I ordered one today! Can't wait until it gets here... Its a great looking car and I applaud the effort put into it.
Curtis
Fantom Racing | On-Point Racing | Parma/PSE | www.4chobbysupply.com
cmenard is offline   Reply With Quote
Old 01-02-2012, 10:42 AM   #41
chicky03's Avatar
Curtis
Thanks Curtis!!
Let us know how it runs when you get it on the track!
Old 01-02-2012, 10:44 AM   #42
chicky03's Avatar
Default Parts List
Here is an updated Parts list for starting from scratch and if you have an R5 already.
Qty Part Number Component Description
1 IRS2132BK Complete 12th rear axle and diff with BB's, Spur Gear etc.
1 12th center shock, AE, Hotbodies, IRS, CRC, Silva
1 Associated Gold and Blue Shock Spring
1 ASC6274 Associated Ball cups, for damper tubes, steering and shock
1 IRS1167 or CLN3381 IRS or CRC Ride height adjusters
1 ASC4635 Associated side links and football
1 ASC4637 Associated link pivot balls (5)
1 SER411070 Serpent S120 Rear Body Mounts (2)
1 SER411040 Serpent S120 Body Mount Adjusting Nuts (4)
1 SER411092 Serpent S120 Front Body Mounts (2)
1 ASC4686 Associated R5 front end
9pcs ASC31280 Short ball stud for bottom center shock mount, damper tubes and servo saver\
1 ?????? Turnbuckles for steering and rod ends
1 KIM210 Kimbrough Medium servo saver
1 OP307 Spring cups and set screws
1 ASC4641 Associated Black Side Springs
1 ASC4653 12R5 Foam Bumper
1 SER411007 Roll Over Antenna
Qty Part Number Hardware
10 ASC21550 3mm low profile nuts
2 M3 3x8 button head screws for rear body mount
27 M3 flat head screws 3x5 (Links, Battery Location, Standoffs, pod plates)
4 M3 3x10 flat head screws for football and front body mounts
4 M3 3x6 flat head screws for front end bulkheads
4 M3 3x14 flat head screws to attach a-arm to suspension mounts
2 M2.5 x 6mm Button Head Screws for football
Parts list if you have R5
24 M3 flat head screws 3x5 (Battery Location, Standoffs. Pod plates)
1 Long ball end for center shock , RPM ball end and Hotbodies shock end work well
1 1mm thick x 6mm OD, 3mm shim for front of shock to mount to shock tower
7 3mm low profile nuts
Old 02-05-2012, 06:21 PM   #43
chicky03's Avatar
Default OP12C Black Edition Tq's and wins 13.5 at the Snowbirds!!!
Report setup and pictures tomorrow.
Congrats Markus Mobers on your tq and win!!
Old 02-05-2012, 09:56 PM   #44
CypressMidWest's Avatar
Great showing for On-Point at the 'birds!!! Markus was fast for sure, with a balanced car that looked like it was easy to drive at a ballistic pace. Way to go Paulie and the rest of the On-Point team!!!!
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 02-06-2012, 07:54 AM   #45
chicky03's Avatar
Default Pictures and setup from Snowbirds!
The third round of qualifying saw Markus Mobers lead from the get go to the end with a new Tq. In the main the tone went off and Markus and his OP12C led start to finish. Markus used the new OP300B Black Edition conversion kit. Now available in black, the OP12C color combo is makes for easier color matching when you convert to it from other 12th cars.
Here is the setup and pictures of the car from the race. If you have any questions please ask.
File Type: pdf OP12C_Markus_snowbirds_2012_13.5_TQ_win.pdf (297.9 KB, 121 views)
On-Point Racing On-Point Racing Team and Company Discussions 402 12-04-2015 03:31 PM
