transmission ratio
I have a TC3 with a transmission ratio of 2.5. Then my yr4m2 has a transmission ratio of 2.2. Given the same gear ratio (spur/pinion), same tire set, and best setup of both cars, does the yr4M2 run faster than the TC3 on the same track ?
Re: transmission ratio
Originally posted by raceblast I have a TC3 with a transmission ratio of 2.5. Then my yr4m2 has a transmission ratio of 2.2. Given the same gear ratio (spur/pinion), same tire set, and best setup of both cars, does the yr4M2 run faster than the TC3 on the same track ? |
