Old 08-23-2011, 09:48 AM   #1
heretic's Avatar
Default BONE BLADE SIZES DATA BASE
Hi everyone,
Bone blades were first seen and called " blades " by Scumacher, UK, if I'm right.
I see lots of people are not satisfied with their bone blades and want to use other brands. This leads to many questions so I figured we could try to create a place where we collect the measurments for each type of blade. I'll start by giving the measurements of the 2 blades I found within arm reach. (The " C " measurement is to guesstimate how far it goes in the diff outdrive.)
Of course, the more precise the better. Any contribution or comment is welcome.
METRIC MEASUREMENTS ONLY PLEASE !
This could go like this ( just copy and paste):
Brand:
Initially intended for the following cars:
Part number:
A = overall/outer width: x.xx mm
B = inner width: x.xx mm
c = depth: x.xx mm
D = pin hole diameter: x.xx mm
E = Thickness: x.xx mm
Note :
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
Old 08-23-2011, 09:48 AM   #2
heretic's Avatar
Brand: XRAY
initially intended for the following cars: T2 008 and beyond
Part number: 305241
A = overall/outer width: 12.20 mm
B = inner width: 6.60 mm
c = depth: 7.58 mm
D = pin hole diameter: 2,00 mm
E = Thickness: 3.53 mm
Note :
Old 08-23-2011, 09:49 AM   #3
heretic's Avatar
Brand: T.O.P.
initially intended for the following cars: Photon
Part number: PO DT0006
A = overall/outer width: 10,13 mm
B = inner width: 5.75 mm
c = depth: 6.85 mm
D = pin hole diameter: 2.04 mm
E = Thickness: 3.85 mm
Note : fits loosely on the stock photon bones (pin diameter hole a bit too large, and inner width too large ) The lighter trick does help though.
Old 02-23-2012, 07:25 AM   #4
heretic's Avatar
Not a large success for this idea I see... I still think it could be helpful so don't hesitate to give 5 minutes of your time to save others time and money !
Apart from that, could someone tell me which brand carries the thickest blades available ? Thanks in advance !
Old 02-23-2012, 08:12 AM   #5
Lonestar's Avatar
My bone is bigger than yours... it's all that matters. Tech threads typically don't raise a lot of passion on the internet
I'll bring specR and oldskool schmacker ones for you to the track saturday so you can measure them... take your calipers!
a+
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 02-24-2012, 09:28 AM   #6
heretic's Avatar
Thanks Paul... I should have foreseen this failure I guess... (sigh) thanks for your help anyway.
Seriously, who makes the thickest blades ? AE ?
I'm looking for something 4mm thick or more, I want to try them in offroad.
