HELP!!! m-05 question
Hello i was wondering what i can do to get my m-05 to go around a turn w/o the back sliding out i have no traction what so ever in the back. This is what i have i have a m-5 with the after market shocker tower running blue in the front yellow in the back im using the stock per mount spec tire as per tcs rules we race on ashplat also. The cars traction is just horrible and i have no clue what to do to correct this i try adjusting the shock to hard setting or softer and it seems nothing works please help if possible thank you
take a picture of yor ride. That'll say alot. Cheers!
You can post and ask at the thread Tamiya Mini Cooper.
If you used the stock shocker,change it!
If you use oil fill shock,try this;
Front and rear
2 hole piston(1.5mm) with 60wt oil 4mm rebound with inner limited of 4mm for mini shock
Spring front and rear
Yellow front and red rear.
I had using this set up with great fun to drive.
Hope this help
Cheers
James
what tyres are you running? try m-grip front s-grip rear.
Check out rc-mini.net's rundown on m05 race setup. I've got most of what they recommend on my mini now and the handling difference is huge!
Here's a link: http://rc-mini.net/joomla/index.php?...=23&Itemid=148
S-grips and m-grips are good for tamiya rules, or m and m.
