Old 11-04-2004, 07:31 PM   #1
JLMG1971's Avatar
Default About the T35BL or any T35
Is it ok to solder both the charger leades and the volt leads, I just don't see the point of conecting both together all the time, 4 alligators clips on the battery instead of only two...
Any problem doing this?
J
JLMG1971 is offline   Reply With Quote
Old 11-04-2004, 07:46 PM   #2
handyrandyrc's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to handyrandyrc Send a message via AIM to handyrandyrc
One pair of the leads is for putting the charge/discharge into/out of the battery. The other pair of leads is for VERY ACCURATE voltage measurement.
The way I understand it, when you detect voltage off the same set of leads you're charging from, there can be inaccuracies.
Since you paid an arm and a leg for the best charger on the planet, you might as well NOT DEFEAT what makes it so great -- VOLTAGE MEASUREMENT ACCURACY.
Randy Clements
Salt Lake City, UT
handyrandyrc is offline   Reply With Quote
Old 11-04-2004, 10:45 PM   #3
wikedgmc's Avatar
Trader Rating: 75 (100%+)
Send a message via MSN to wikedgmc
so how do you attach the other leads and were do you connect them??
Powered by HobbyTown San Jose
wikedgmc is offline   Reply With Quote
Old 11-05-2004, 08:21 AM   #4
newracer's Avatar
directly to the battery with the small aligator clips on them
newracer is offline   Reply With Quote
Old 11-05-2004, 10:34 AM   #5
Hmm. So if you are connecting the charger leads and the voltage leads to the same place on the battery, how is this any different than just soldering the voltage leads to the connectors used by the charge leads?
kcobra is offline   Reply With Quote
Old 11-05-2004, 12:00 PM   #6
Call Competition Electronics and find out WHY. You must be more brilliant than their engineers, so give 'em a call...
Randy
Old 11-05-2004, 02:15 PM   #7
Bite me. I was just asking a question and didn't deserve your sarcastic reply.
Old 11-05-2004, 03:12 PM   #8
myclod's Avatar
Send a message via AIM to myclod Send a message via Yahoo to myclod
now children....calm down....there is a reason for it, i dunno what it is, but i have seen many a racer tie both sets into one alligator clip with no adverse results but the small wires only need to be used during discharge
myclod is offline   Reply With Quote
Old 11-05-2004, 03:26 PM   #9
jsp
If the volt leads and the current leads use common alligator connectors there can be a large error in the voltage reading, especially during high amp discharge. If separte connecors are used, there is no voltage drop/ loss across the meter leads and the readings are accurate. This error can be be as high as .3-.4 volts. If you use only one connector, you can minimize the error by soldering the current lead to on side of the clip and the meter lead to the other side.
jsp is offline   Reply With Quote
Old 11-05-2004, 03:44 PM   #10
kcobra:
The small leads attach internally to a voltmeter. The seperate leads are required for a more acurate reading because during charging and discharging the input/output current fluctuates and in effect causes noise that may result in false peaks while charging or having the discharge cut-off before you want it to.
It is a matter of how accurate you want to be. The Turbo Chargers all take readings from both leads but to insure you don't cook your batteries, it is highly recommended that you use the small leads for charging and discharging. Its part of how the unit is designed.
If you have more questions you should contact
"Jim Bailey" <[email protected]>
LeadFoot is offline   Reply With Quote
Old 11-05-2004, 10:05 PM   #11
newracer's Avatar
Default Quote from CE website
The voltage sensing leads (small wires) are not dependant on length. You can make tem any length you want. They need to be connected to something that is soldered directly to the battery. That is why we make them separate from the current wires (large wires). There is a voltage drop at the point where the current jumps from the battery terminal to the current clip. If you solder them to the current clips, or attach them to the current clips, the voltage is being measured after the drop occurs. A typical error would be about .30 volts with a 30 amp discharge rate. That means your 6 cell pack will cut off at 5.70 volts instead of 5.40. The current carrying wires can be lengthened, but if you want to discharge single cells at 35 amps, the wires will need to be kept original length. The calibration of the unit is not dependant on wire length, but its ability to control current at the extremes may be compromised when a lot of wire is added.
competition electronics t35bl JasonC R/C Items: For Sale/Trade 9 01-17-2005 02:00 PM
T35bl fs $220 shipped$ sharkman R/C Items: For Sale/Trade 10 09-17-2004 10:02 PM
Fs: Ce T35bl Tres R/C Items: For Sale/Trade 3 12-26-2002 10:19 AM
T35BL for Sale R6 R/C Items: For Sale/Trade 10 08-24-2002 01:27 PM
DATA Port on the CE T35bl mike_Webb Electric On-Road 3 12-27-2001 01:42 PM
