Problem With Spur and Pinion
Hi there... ;)
Im really need help, as im not good in fdr counting, for your info im using sakura zero with Turnigy Track 100a ESC and Orca RX2 10.5t (Sensored) motor, Now, after changing Spur to 83t and Pinion 26t my car has no top speed, Great on Tork but no top speed, and im really cant remember the original spur and pinion.., did spur and pinion conversion really give impact on car top speed.. Sorry... Im Newbie :blush: |
Originally Posted by rekomaster
(Post 9550688)
Hi there... ;)
Now, after changing Spur to 83t and Pinion 26t |
Originally Posted by RogerDaShrubber
(Post 9551269)
Changed from what?
formerly, it use 80t spur and 26t pinion at the front, and i've change it to 83t spur and 26t pinion....never touch rear, it still use stock Gear Ratio: 38t/20t and im using IP Batteri 6200mah/70c... Lee |
Smaller SPUR- more top speed (hotter temp)
Smaller PINION- more Torque (cooler temp) Bigger SPUR- More Torque (cooler temp) Bigger PINION- More top speed (hotter temp) |
