Old 11-04-2004, 01:44 AM   #1
Send a message via AIM to (V)r>??@uD@ Send a message via Yahoo to (V)r>??@uD@
Default CDC light gone out
hey
i was just charging my batteries on my CDC version 6/b ( the eagle one) and the light the backlit light has gone out
was going on ??
could that be from too many charges
Can i be fixed by myself ??
does this happen normaly????
Please help I have no idea
(V)r>??@uD@ is offline   Reply With Quote
Old 11-04-2004, 01:53 AM   #2
MrRolla's Avatar
Trader Rating: 29 (100%+)
Unforunatley its a common problem, it will probably come back on in a few weeks if its anything like my mates
MrRolla is offline   Reply With Quote
Old 11-04-2004, 01:59 AM   #3
so do you mean that its having a break and i will come back i hope so because it hard to see in the dark i hope it comes back
I dont know do you ????
Old 11-04-2004, 02:03 AM   #4
pink pac man's Avatar
im thinking of getting a cdc ver 6.0 does this happen to all of them
pink pac man is offline   Reply With Quote
Old 11-04-2004, 02:16 AM   #5
Default Re:
hey does this also effect the way the batts charge i have not idea thanks for helping
Old 11-04-2004, 02:50 AM   #6
AdR|aN's Avatar
Send a message via ICQ to AdR|aN
Its a normal problem.
I believe it happens to almost 80% of CDC v6.0B charger.
It does in no way effect the chargers capabilities.
AdR|aN is offline   Reply With Quote
Old 11-04-2004, 02:57 AM   #7
That sucks and its not fair you pay a bit of money for a good charger and it has problems
Old 11-04-2004, 03:04 AM   #8
Carbon_Fibre3's Avatar
i emailed eagle.. or integy who ever you fancy, and they said the leds screens blow from an input voltage over 14 volts
Carbon_Fibre3 is offline   Reply With Quote
Old 11-04-2004, 03:24 AM   #9
AdR|aN's Avatar
Hmm ... sounds unbelieveable .... mine has gone out and came back a few times ... currently since i don run discharge anymore, the light seems to stay there longer ...
If the LED does really blow, it wouldnt turn back ON right?
Funny! Guess maybe its one of the connection inside.
I had an electrician check and he said there was nothing wrong.
Old 11-04-2004, 03:46 AM   #10
mine doesnt come bak on.. so mine is blown..
this could be a reason for some of the malfunctions..
as for ur intermittent one.. mayeb its got to do with thermal expansion? gets hot then seperated connection, cools and comes bak? just a stab in the dark
Old 11-04-2004, 03:31 PM   #11
Cole Trickle's Avatar
In 3/4, it has only happend to mine once. And it was for a short time. A little tapping can often fix the problem. No blown LEDs, just bad connections. Sad in such a product...
Anyway, one thing you have to take into account, is the VESC charging algorithm.
The good thing is that this charger never ever false peaks... But this almost also implies the problem with this charger; It pushes the cells harder. This is of course an advantage in stock class. But I'm not so sure about the battery life time. Personally I havent observed any problems yet, but cant be sure...
The thing is, that the charger charges for 55 seconds. Then it pauses for 5 seconds, charge 55 sec., pause 5 sec., and so on. The charger looks for the voltage drop WITHIN these 55 seconds. So if the pack voltage drops very little very slowly, then the charger wont stop. I've charged a AA cell, and after 7 hours, it hadnt stopped yet... Needles to say, I dont charge AA and the likes on this charger anymore....
The result is, that packs like 6 cells GP 3300, is quite warm and sometimes hot after a charge, even with delta cut off as low as 3 mV pr. cell. This is especially a problem, if ambient temperature is above 22-25 degrees celsius (71-77F). Most of the time I'm charging at 17-20 (62-68F), so it's not a problem for me.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
ott-light Zac R R/C Items: Wanted to Buy 5 05-15-2008 02:10 AM
pit light heffer Electric Off-Road 4 01-21-2007 02:38 AM
Pit Light dway100 R/C Items: For Sale/Trade 8 02-06-2005 11:39 AM
WTB .. OTT Pit light JDM_DOHC_SiR R/C Items: Wanted to Buy 22 09-23-2004 02:12 PM
Light up gearless Electric On-Road 3 12-01-2003 05:51 AM
