Old 11-03-2004, 04:19 AM   #1
pink pac man's Avatar
Default lrp pulsar discharge
i have a lrp pulsar and when i discharge it cuts it off at 7.something volts instead of 5.4 volts
can any1 help me
pink pac man is offline   Reply With Quote
Old 11-03-2004, 04:23 AM   #2
Send a message via AIM to Javen13 Send a message via Yahoo to Javen13
did u adjust the cutoff under the settings
Javen13 is offline   Reply With Quote
Old 11-03-2004, 04:25 AM   #3
i go into settings then to discharge than it says 5.4v
have i done it rong
Old 11-03-2004, 04:30 AM   #4
Trader Rating: 70 (100%+)
Send a message via AIM to TexRacer
In all honesty Pink you wanna invest in a different Discharger if racing.
10 amps simply isnt good for racing packs if you wanna keep them trained for racing.The ONLY downfall of the LRP Pulsar.
Invest in a Integy Reactor 30 amp or some sort of Digital Discharger.
I have seen what 4,10 amp discharging does to a pack over 10 charges and it isnt pretty.
*****Look me up on Ebay. I will have alot of stuff going up as 7/7/2016. User name is Dalracer.**** This is going to be a BIG ONE!!!!!!
Just wanted to say Thanks to RcTech for all these years of Great Information.
TexRacer is offline   Reply With Quote
Old 11-03-2004, 04:34 AM   #5
so im only making things worse by discharging them at 10 amps...............whould it be better to not discharge them at all
Old 11-03-2004, 04:54 AM   #6
JDXray's Avatar
Send a message via AIM to JDXray
I just recently got the LRP Comp 2, and its nice and all just needs a boost on the dischargin rate. I dont discharge my packs on that charger, you can go out and buy a Integy INDI Reactor 30 amp for like 30-40 bucks. I will hopefully soon get one of those, but as of now i just run my packs store them and then tray them on my smart tray.
hope it helps
Jon
JDXray is offline   Reply With Quote
Old 11-03-2004, 04:58 AM   #7
i dont have a tray and the only way to discharge them is on the pulsar or on the lrp nimh discharger
Old 11-03-2004, 05:09 AM   #8
FlyinGT's Avatar
Send a message via AIM to FlyinGT Send a message via Yahoo to FlyinGT
build urself a bulb discharger .... if u use tail light, light bulbs about 10 to 12 bulbs should do ... kinda like the deans discharger
or u can use lamp bulbs ..an make it even smaller ..
cost about 10 to 15 buck aussie
i use one ...
i think my one discharge at bout 20amps ...
FlyinGT is offline   Reply With Quote
Old 11-03-2004, 09:47 AM   #9
What does the LRP discharger discharge AT?What AMP rate?
If thats all you can afford then YES discharge at 10 amps.
But as soon as you can upgrade to a 30 amp discharger or 12-15 car bulbs made together.
Old 11-03-2004, 09:48 AM   #10
JDXray's Avatar
Les, the LRP Chargers discharge at 10amp either fixed (LRP PUlsar 1) or adjustable 1-10amp (LRP Pulsar 2) I think thats right
Jon
Old 11-03-2004, 09:51 AM   #11
Moderator
Clegg's Avatar
Unfortunately the reactor doesnt work well at all with 4 Cell packs. (cuts off to high since its set to work with a 6 cell pack not a 4 cell.)
I use the LRP myself as a discharger (or just race the packs till they dump). Such is life.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 11-03-2004, 09:52 AM   #12
JDXray's Avatar
What cutoff should 4 cells be at?/
Old 11-03-2004, 09:57 AM   #13
Moderator
Clegg's Avatar
3.6v
Old 11-03-2004, 09:57 AM   #14
JDXray's Avatar
3.6v
Thanks you
Old 11-03-2004, 10:00 AM   #15
Moderator
Clegg's Avatar
Got me thinking now, I am gunna go and open up my Reactor 30 and see if theres a way to tweak the cut off voltage
Pulsar 2 , Novak Discharge Tray , Indi Reactor , Cobra lathe , OS 2050 Pipe turd ferguson R/C Items: For Sale/Trade 16 03-30-2008 10:02 AM
LRP PULSAR 1 CHARGER IN GREAT SHAPE WITH TRINITY DISCHARGE TRAY DENNIS STORTI R/C Items: For Sale/Trade 3 08-06-2007 09:04 AM
motor lot, lrp pulsar competition, discharge tray, spring dyno, indi torpedo: CHEAP billjacobs R/C Items: For Sale/Trade 8 11-02-2006 11:08 AM
LRP Pulsar Charger, Integy discharge Trays, Servos, Tekin G10 speedo barnacle R/C Items: For Sale/Trade 15 10-07-2006 09:59 PM
Pulsar Discharge thecrow2k Electric On-Road 4 11-10-2005 04:17 PM
