Old 11-02-2004, 01:46 PM   #1
Paul_TC4's Avatar
Send a message via AIM to Paul_TC4
Default TC3 Steel Outdrive Trouble
I just bought the steel outdrives for my electric TC4. Im doing this as a replacement of the plastic ones because they break on me alot. Now these outdrives are completely different. They are them same size but the lock nut that holds the thrust screw in wont fit in the short outdrive because it doesnt have the mold where it holds it in. What do I use as a lock nut to hold the diff together?
thanks,
Paul
Paul_TC4 is offline   Reply With Quote
Old 11-02-2004, 01:51 PM   #2
howard hudson's Avatar
R/C Tech Charter Subscriber
the lock nut is different then the one used in the plastic diffs. also the spring and lock nut goes on the long half. I would suggest down loading a tc3 manuel off the ascocoiated web site so yopu get a pic of the steel diff
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline   Reply With Quote
Old 11-02-2004, 01:54 PM   #3
Speedie's Avatar
You need a t nut. the nut is molded into a piece of plastic that sits in the slots instead of fitting inside the outdrive end. Ask at your LHS they will know what ya need Its PN 6575
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 11-02-2004, 02:08 PM   #4
Paul_TC4's Avatar
speedie, I have this T-nut, I should have mentioned this before. It came with my nitro.
Now my question is, where do I put the spring, thrust assembaly and the tnut. (which outdrives?)
Thanks,
Paul
Never mind. I should have read Howard's post more throughly. Thanks for the help guys.
Old 11-02-2004, 02:18 PM   #5
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Spring and T-nut go in the short outdrive, thrust assy and bolt got in the long side.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 11-02-2004, 02:27 PM   #6
You will also need different diff rings for the steel outdrives, I think. If you get the rebuild kit you'll definitely have everything you need.
TPJ International
071crazy is offline   Reply With Quote
Old 11-02-2004, 03:33 PM   #7
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
Unless things have changed, which the may have, you will need different bearings too.
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 11-02-2004, 06:09 PM   #8
Paul_TC4's Avatar
I have all the things I need to run the steel outdrives.
1 MAJOR problem: The diff rings that go on the outdrives are too small. This causes the diffs not to close properly. Im using the diff rings that came with my NTC3. Im gonna take a trip to my LHS and see if they have the proper diff rings.
Paul
Old 11-02-2004, 06:12 PM   #9
Paul_TC4's Avatar
Jack Smash, are you sure the spring and T-nut go in the short outdrive?
Im pretty sure that they go in the long half because it wouldn't fit inside the short one.
I think Howard has the right observation.
Old 11-02-2004, 06:47 PM   #10
Mike Haynes's Avatar
The spring / t-nut go on the longer side, the trust balls go on the hsorter side (this works the best).
As for the rings, the ntc3 round ones should work just fine, the diff not "closing" enough is most likely due to the bearings being too wide, i always found using more narrow bearings to be helpfull.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 11-02-2004, 07:09 PM   #11
Paul_TC4's Avatar
Rcracingkid, my NTC3 diff rings dont fit on the outdrives at all. They dont even go around the small circle on the outdrive. This causes a gap in between the diff gears and the outdrive which makes it impossible to screw in the thrust assembaly screw into the T-nut.
Old 11-02-2004, 07:52 PM   #12
hey dude click here and down load the tc3 manuel or if this works click this
Old 11-02-2004, 08:02 PM   #13
Jack Smash's Avatar
My bad guys. Spring and nut go in the long side, Thrust assy go is the short side. I was thinking of my old offroad days.
Old 11-02-2004, 08:06 PM   #14
Originally posted by Jack Smash
My bad guys.
well aaaaaaa yes !!!! yes you are bad!!!!!! just b busting ya bud
Old 11-03-2004, 02:22 PM   #15
Paul_TC4's Avatar
Ok guys, I figured out the problem. The diff didnt close right because I was using the NTC3 rings which looked like they fit in the outdrives but they didnt seat correctly.
thanks for the help guys.
Paul
WTB XX4 outdrive savers Autocrosser R/C Items: Wanted to Buy 3 03-27-2008 10:33 PM
tc4 steel outdrive question??? budget man Electric On-Road 2 02-19-2008 05:51 PM
WTB: Barra one-way outdrive Dorigecko Australia Wanted to Buy 0 01-03-2008 11:35 PM
Xray multi diff spring steel outdrive bigdog xxx-s R/C Items: Wanted to Buy 2 10-17-2007 01:58 PM
Losi xx4 Outdrive savers NEW!! b4dabest R/C Items: For Sale/Trade 1 07-25-2007 11:53 AM
