Old 08-14-2011, 09:59 AM   #1
Default having troubles with steering linkage
this might be a dumb question but was wondering if anyone has some easy ways to installing the steering rod to the adjuster end, having a hard time putting them in
ragingdemon is offline   Reply With Quote
Old 08-14-2011, 10:33 AM   #2
Skiddins's Avatar
I usually try to hold the rod part in a part of pliers (you have to hold it tight) then try to screw the ball end onto the rod instead of the other way around.
If the problem is just trying to get the threaded rod 'started' into the ball end , perhaps gently use a body reamer in the end of the ball end to make a cone shape that the threaded rod will then screw into.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-14-2011, 11:54 AM   #3
thanks that worked!, such a hassle trying to not scratch it with pliers too
