Understanding Dyno Data
We have been playing around with some dynos recently, however it seems it is very important to know how to interpret the results, rather then checking maximum figures.
For example:
- What is the most current a modified motor can draw on acceleration?
- At max revs, what current will modified motors use?
I know motors vary, I just need an idea of what to expect
Thanks everyone for the help
For example:
Have a look for example these two motors ...
Motor 2
We will be more than grateful if someone can explain to us the difference between the above 2 motors. Thanks a lot
Those plots almost look like the same motor with different springs.
The first motor has more high RPM power than the second one so it should have more power at the end of the straight. The second motor has more power under a heavy load and should pull harder coming off the slower corners.
There's a whole bunch more that you need to think about when comparing two motors. What class, race length, and the number of cells all play a pretty big role when deciding what motor is better.
The above motors are used on 1/10 touring cars in open modified class 5 mins races. To be more precise they are both 8 single motors. One with timing 4 deg and the other one with timing 5 deg.
How much current is normal for such motors to draw on acceleration and on top revs? Any other comparisions are more than welcome
For the tight carpet track I run on and a 19T motor, I've measured current draw at over 70A from a standing start. The average amp draw for a 5 min. race for the same motor was aroun 25A, with currents just over 40A as the car accelerates out of the corner. If I remember right the amp draw dropped off to around 10A at the end of the longest straight before I got out of the throttle.
Great input Steve R...any body has an idea of current draw figures from an 8 single ?
So modified low wind motors draw more than 70 amps from a standing start
The amount of time that the motor pulls really high current is actually pretty short. Most mod motors in sedan will average around 35 amps or so on the track.
The amount of current that the motor draws at the end of the longest straight depends on gearing. That's why you dump if you put too much gear on it.
It's pretty rare that we actually run an 8 turn on the dyno. There's more than enough power with an 8 so getting another 5 watts is no big deal.
5 deg of timing does sound a little low though. I seem to remember running 12-14 deg with the new Reedy stuff.
