Old 08-13-2011, 09:25 AM   #1
Default swaybar Q.
I have a shaft tub chassis madspeed i put swaybars on it and everytime i took off it would pull to one side and very hard to drive.I took both of them off and it's nice and straight and easy to drive.I thought sway bars made it handle better.
bosco72 is offline   Reply With Quote
Old 08-16-2011, 05:06 AM   #2
no one has any input why it does this.
Old 08-16-2011, 05:08 AM   #3
put a picture of your car, are you sure you put them in the right place?
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 08-16-2011, 05:28 AM   #4
I put them how they said to put them on. there are grooves in the end of the gear boxes do i tighten them so they can't move or do i want them to move under the screws
Old 08-16-2011, 05:48 AM   #5
AM03GT's Avatar
Swaybars/Antiroll bars can also cause tweak if not setup correctly. First off the bar should ride smooth and free underneath those 2 screws. If you pinch the bar and it is not allowed to glide freely then you are basically adding a spring to each side of the car...
To get it setup correctly remove the shocks and hold the car upside down and compress the arms left then right. Holding the left side (full droop) see how much the right side drops down... Then hold the right side (full droop) and see how much the left side drops down. Adjust the mounts until the "drop" is identical and the bar should work properly without tweaking... You can do a similar setup with measuring tools but its more intensive and timely...
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
Old 08-16-2011, 07:32 AM   #6
thanks alot for your help.
TC3 Forum Lowrider Electric On-Road 12196 10-13-2017 09:47 PM
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 08:38 PM
VTA tuning Q&A liljohn1064 Electric On-Road 500 06-06-2011 01:21 AM
