Old 11-01-2004, 06:12 PM   #1
Default Motor Dyno
I am shopping for a motor dyno. What brand and what models are available in the market?
raceblast is offline   Reply With Quote
Old 11-01-2004, 06:20 PM   #2
berger's Avatar
R/C Tech Charter Subscriber
CS do a good one i believe.
berger is offline   Reply With Quote
Old 11-01-2004, 06:26 PM   #3
Fuzzy's Avatar
Default Re: Motor Dyno
CE TurboDyno - discontinued but you may find some for sale on Ebay or the For Sale forum here on RCTech
Robitronics - same as above.
CS Electronics - Imported from Europe. Still made, but tough to get parts and service for.
Fantom Dyno - made and serviced in the U.S.
Fuzzy is offline   Reply With Quote
Old 11-01-2004, 06:42 PM   #4
Moderator
Speedo's Avatar
I would say the CE TD45 would be your best bet if you can find one, then the robi and CE come in tied for second, with the fantom in last.
Speedo is offline   Reply With Quote
Old 11-19-2004, 07:20 AM   #5
Someone is selling a CE turbodyno 30 locally? Since everyone in the local track is using Fantom Dyno, I need more info about the turbodyno 30. Does it need a computer to work? Does it take power from 12V power supply? What are the new features of the turbodyno 45?
Could anyone post the official web site of Robitronics dyno please?
Old 11-19-2004, 07:24 AM   #6
The Robitronics is not discontinued, having used both I would place it obove the CS one for sure. (More consistent)
vassago is offline   Reply With Quote
Old 11-19-2004, 08:45 AM   #7
vtl1180ny's Avatar
I have a CS and I'm very happy with it.... Unlike the Robitronics you can use it without a computer also....
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 11-19-2004, 08:53 AM   #8
dgullickson's Avatar
Trader Rating: 45 (96%+)
Send a message via AIM to dgullickson Send a message via Yahoo to dgullickson
The CE TD - 30 or 45 does not need a PC to run. It uses a 12V Power supply and depending what you are testing will determine your size of Power Supply needed. The TD 30 they Rec. a 30A and the 45 they rec. a 45A. I have a CE TD 45 and use a 45A Power supply. I would recommend this Dyno to anyone as it puts a load on the motor you are testing therefor you are getting close results to the track - track is still the best Dyno!
dgullickson is offline   Reply With Quote
Old 11-19-2004, 08:57 AM   #9
You can use the Robi without a computer, please get your facts straight before posting.
The CS will always be off a few watts with every run due to it being power by normal battery packs. This can also be seen as a plus but for me it is just a pain in the behind.
On the Robi every run is identical to the run before if the motor doesn't change.
The price on the CS is a lot better than the Robi though. It's hard to justify 2 times the amount of money for the Robi when both do nearly the same things.
Old 11-19-2004, 09:02 AM   #10
Does CE still make TurboDyno 45, or is it discontinued?
Old 11-19-2004, 09:04 AM   #11
What is this CS dyno that u are talking about? I only know CE turbodyno, Fantom and Robitronics.
What is the latest model of the Robitronics dyno?
Old 11-19-2004, 09:04 AM   #12
As far as I know they stopped making them. I got 2 that I use and love them! I couldnt pass up the deal I got for buying 2 from a guy... They do still do the slave motors though and continue to Service them.
Old 11-19-2004, 09:12 AM   #13
vtl1180ny's Avatar
If running the CS of the battery packs you use is a problem you can always run the motor off a 6 volt battery.....
Want the best dyno??? Get an Eagletree data recorder.... Then you can test everything right in your car.....
I still lurk....
Old 11-19-2004, 12:55 PM   #14
serpentracer1's Avatar
Send a message via AIM to serpentracer1
I was told from a reliable source that CE is considering releasing a dyno again.I have one and love it
DAVE (THE SNAKE) Rasnake
Original Mimi Wong Clan. M.W.C. For Life
Associated B6D
Orion R10 Pro VST powered
serpentracer1 is offline   Reply With Quote
Old 11-19-2004, 11:42 PM   #15
EddieO's Avatar
Good luck finding a Turbodyno....have not seen one in a while up for sale.....and if one does pop up, good luck out bidding me!
The Robitronic is still made, and can be used without a computer. I have it, a turbodyno, fantom, and CS.....the CS in my opinion sucks.....never do you get very consistent results....
I think someone who has two TD45 dynos should sell me one!!!
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
*** F/S: Motor Dyno - Integy Indi Dyno *** KenSmith R/C Items: For Sale/Trade 11 09-27-2007 07:53 AM
Integy Indi Dyno v2 motor dyno SpeedChair R/C Items: For Sale/Trade 4 08-14-2006 10:30 PM
Looking for a CE motor dyno AlanLim R/C Items: Wanted to Buy 0 08-25-2004 11:03 AM
Indi motor dyno vs. Orion Motor Perf monitor j240z Electric On-Road 5 08-07-2004 03:58 PM
Motor dyno Mad Mackem Australian Racing 9 05-26-2003 01:51 AM
