Old 08-12-2011, 01:46 PM   #1
Geberit's Avatar
Default Putty or gear oil!?
I would like to use a front gear diff in my TC6 and don't know whether to use putty or diff oil (600000 Mumeisha) that's the densest I found!
For me the Putty sounds odd since the gears can push the putty away!?
And anyway can someone explain me the method how to stuff the putty in the diff so that it will work constant during a run ...
Regards, G
Geberit is offline   Reply With Quote
Old 08-12-2011, 01:57 PM   #2
Foxxrocket's Avatar
Non-hardening putty is used to make the front diff more like a spool. The internal gears will still be able to move, but just bearly.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 08-12-2011, 03:11 PM   #3
RC MARKET's Avatar
oil !
RC MARKET is offline   Reply With Quote
Old 08-12-2011, 08:36 PM   #4
I've used silly putty in the diffs of my formula off road truck with great success. I just stuff the diffs as full as I can. On road may be different when you need consistant handling. Eventually the putty turns into a syrupy goop that does kind of flow back into the gears. It may be worth a shot.
cwazyduck is offline   Reply With Quote
Old 08-13-2011, 10:05 AM   #5
Rick Hohwart's Avatar
I have had great luck with cleaning putty. It is pretty consistent from run to run and within a single run. I ran my putty filled diff through the entire Reedy Race, a couple of test days, and the entire ROAR Nats with no difference in feel.
Rick Hohwart is offline   Reply With Quote
Old 08-13-2011, 01:28 PM   #6
Geberit's Avatar
Today I spoke with Juho Lovanen at Euros. He gave me some advice how to do it with putty.
By the way, nice diff from Associated for the TC6, can't wait for it
G
Old 08-13-2011, 05:48 PM   #7
whats the best way to put the putty in the diff? any special way or just jam it in the diff?
Team Associated TC7.1 - Hobbywing - Highest - Sanwa - Gens Ace
Team Associated B5R - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 08-13-2011, 06:14 PM   #8
Jochim_18's Avatar
all my buddy packed the gear diff with grease (Heavy Equipment machine Grease) on their 1/8th buggy center gear diff and it holds up without slip. I say this should be fine when using it on the front gear diff on a touring car but I haven't tried it myself.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Tamiya mini cooper sipaboy Electric On-Road 29687 12-10-2017 04:07 AM
Front Gear Diffs with oil/putty users - Pls explain!!! danjoy25 Electric On-Road 54 07-24-2014 04:18 AM
GEAR diff or BALL diff ? lightfoot Electric On-Road 103 06-04-2012 04:54 AM
Short course truck debate: gear diff vs. ball diff FrankB Electric Off-Road 23 06-16-2010 04:34 PM
