Old 08-12-2011, 07:38 PM   #16
skypilot's Avatar
Trader Rating: 14 (100%+)
this is from the included sheet of paper with rp30's mind you this is from before they changed the rubber.
rp 24 ground surface temp 5 - 30C 30 - 86F
rp 30 ground surface temp 15- 50C 50 - 122F
rp 36 ground surface temp 25- 60C 68 - 140F
rp 40 ground surface temp 40- 70C 104 -156F
wish there was a date on these, but pretty sure they were from Adams old stock.
semi retired..
skypilot is offline   Reply With Quote
Old 08-12-2011, 08:00 PM   #17
HarryLeach's Avatar
Send a message via AIM to HarryLeach
Spec sheet on the new stock RP's are the same as you posted.
Also no year coding.
I've found very little difference between the old stock and new stock tires though, so RP's reformulation is quite good.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 08-12-2011, 09:08 PM   #18
Trader Rating: 48 (93%+)
Adam if they work good. can you get any more or do you have any more? i will make sure to take care of these tires.
tcb22185 is offline   Reply With Quote
Old 08-13-2011, 08:56 PM   #19
These tires kicked butt the 1st 3 or 4 laps untill the paint they used on the servise of the track started to peel up and stick to the tires..
Then They where junk every tire i tried did the same thing. best set was the salories H Compound track temp was 114F
Old 08-13-2011, 09:01 PM   #20
Damnit Man's Avatar
Send a message via MSN to Damnit Man
Paint on the track? What track are you running at?
Donovan P.
Damnit Man is offline   Reply With Quote
Old 08-13-2011, 09:30 PM   #21
You got PM
FSEARA 2009-2010 Spec Tire turbodog Florida Racing 50 07-14-2009 07:16 PM
T2'008 M11 SpeedPassion RP-30 EnerG 4600's and more.... Sean R R/C Items: For Sale/Trade 44 07-02-2008 10:17 AM
Best rubber tire Aluma Electric On-Road 98 12-21-2006 08:04 PM
ON-ROAD TIRE LOT CS 27's, CS 30's, RP 30's RED-LINE M03 R/C Items: For Sale/Trade 18 05-23-2006 06:14 PM
