Shock Rebound
Hi all
What does everybody run there shock rebound set at, for a smooth track, bumpy track, tight twisty track, open flowing tracks. not a lot is said in car kit instructions and setup books about shock rebound, I run my son's at 75%, looking to see what others run. Regards Gary |
Normally I aim for 2-3mm of rebound, in general.
Good Question
Gary
I also would like to know whats best on this subject. Personaly I like to run 100% rebound on our track as it has some bumpy section, which i think the car rides alot better. I think the rebound holds the tyres down on the road instead of skipping over parts. I'm going to see how this works at the Gold Coast track this weekend. Cheers Todd |
Originally Posted by XRAYGIZMO
(Post 9506070)
Gary
I also would like to know whats best on this subject. Personaly I like to run 100% rebound on our track as it has some bumpy section, which i think the car rides alot better. I think the rebound holds the tyres down on the road instead of skipping over parts. I'm going to see how this works at the Gold Coast track this weekend. Cheers Todd Let me put it this way, for full fast rebounds, my car rolls and skates everywhere. for slow full rebound, it grips better, and traction gets even better as the shocks lose its full rebound over 1 or 2 packs. |
i tend set my shocks with 0 rebound and let the springs and oil do the work. this way i get to set my shocks more consistently between rebuilds.
+1 :nod: On the "Zero" Rebound.
I have been in RC for a long time, and I truely think shock rebound is something you just "cannot" do "consistantly" on all 4 shocks.... With practice you may be able to come close, but it is like trying to make lightning strick twice in the same place, you just can't do it. Then if some oil leaks out of one shock..... you just lost your handling.... The shock "spring" is the shock rebound. That is the purpose of having the springs there, and being able to change springs. Build your shock with Zero rebound and let the spring do the work. You get consistant handling, and handling you can actually change by changing the springs. And if you don't think your shocks are reacting quick enough on a rough track, increase the number of holes in your pistons, or go to a lower weight oil. For a rough track, I like 4 large holes in my pistons, with a mid to heavy weight oil. The shocks move quick enough to respond, but are Very Smooth because of the thicker oil. |
Originally Posted by StarrRacing
(Post 9506307)
(Post 9506307)
When ever i set zero rebound i get negative rebound!!! I am sure i am doing it the wrong way or over doing something.
Originally Posted by dex410usa
(Post 9508252)
Thank you
Originally Posted by P.I.M.P
(Post 9508339)
Hi you are not doing any thing wrong negative rebound is a trade off when running 0% it seems not to affect the handling if you can find a very soft blatter it will help with negative rebound.and all so if you are getting zero rebound with out a hole in the cap then put a hole in will help to.
Setting the rebound must vary from car to car. I followed a schumacher video on it but trying to replicate on my tc5 didnt work at all. Needed to put 2mm clips on the shaft otherwise the rod would hit the diaphram when i tried to bleed it.
So aiming for 2-3 mm netted ne half the shock travel. Shocks seem very fiddly and after one race theynseem to leak and the settings are all off again. |
youtube.com/watch?v=HNJy7kreK90&feature=youtube_gdata_player
Try this, I know he is building a 1:8 shock but it is the same theory Btw: I can not post url's |
When I build Schumacher shocks with 100% rebound, the cars seems very darty and unsettled. I've played with less rebound, but haven't done enough focused testing to be really confident of the results. The car does seem more settled, but it seems like they may pull air in and go flat after just a race or two.
On the advice of one of the local fast guys who swears by holes in the cap, I got myself a pin vise and some small drill bits, and got to work. It took some patience with the aluminum caps. The holes are something like 1.5-2mm, which is probably bigger than ideal, but I messed up the first one and felt like I should do them all the same. :blush: With this set of shocks, I build them with "100%" rebound... i.e. I pull and hold the shaft all the way out, gently press the bladder in, and then put the cap on. Like this, the shocks are basically "dead". The shaft just stays where I left it. If I push it all the way in, it'll rebound a few mm very slowly. The car handles smooth and consistent, and they seem to stay that way for quite a while without needing a re-bleed. -Mike |
(Post 9508339)
Jilles has a video showing how to build shocks with zero rebound
| All times are GMT -7. It is currently 09:30 PM. |
