Old 08-06-2011, 02:09 PM   #1
Cool Will muchmore master charge this battery?
http://www.amainhobbies.com/product_...ck-2500mAh-M11
If it does, which adapter should I get with it? If it doesn't, which charger should I buy?
Thanks!
halayli is offline   Reply With Quote
Old 08-06-2011, 07:11 PM   #2
Aaron Waldron's Avatar
Which Muchmore charger is it? Muchmore currently lists the Cell Master Legend, and the Cell Master Platinum, and both are capable of charging that battery (which is an 8-cell NiMH pack).
You'll need an adapter with a female Z-connector. You could get something like this and either cut the banana plugs off to expose bare wire, or clip the alligator clips onto the banana plugs:
http://www.amainhobbies.com/product_...-w-Banana-Plug
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 08-06-2011, 08:29 PM   #3
Ah this adapter is exactly what I was looking for!
This is the muchmore product I have :
http://www.muchmoreusa.com/chargers/mmrp1000.html
Thanks!
Old 08-06-2011, 08:42 PM   #4
Thanks!
I just noticed, isn't the battery and the plug both female?
Old 08-06-2011, 09:07 PM   #5
one more question.
What charger do you recommend for this battery:
http://www.amainhobbies.com/product_...-ROAR-Approved
Old 08-06-2011, 09:57 PM   #6
MattFromSooke's Avatar
Send a message via Skype™ to MattFromSooke
http://www.amainhobbies.com/product_...iCd-DC-Charger
6 Ps of racing: Proper Preperation Prevents Piss Poor Performance
MattFromSooke is offline   Reply With Quote
Old 08-07-2011, 04:06 AM   #7
Thanks! I liked it and placed an order.
Old 08-08-2011, 11:49 AM   #8
halayli, I'm sorry that I didn't get to your questions before you placed the order.
Receiver and transmitter batteries use the male plug, which is backward from car packs.
As for the charger I'd recommend to charge your ProTek packs, it'd be this one:
http://www.amainhobbies.com/product_...S-10A-200W-x-2
Less expensive than the LRP charger, and you can charge two packs at once (with the right power supply)!
www.liverc.com
Old 08-24-2011, 02:49 AM   #9
Hi guys,
i need some comments over here. My muchmore master legend charger doesnt charge up my batts because it shows high voltage from the batts.
Is it fuse blow or some other reasons?
Champagne showers
theoneandonly is offline   Reply With Quote
Team Much-More cell master v1 lee82gx Electric On-Road 1656 05-22-2009 08:16 AM
Battery meaning. cyclone speed Electric On-Road 21 01-24-2009 09:11 AM
MuchMore CTX-D Discharger TeamMuchMore Radio and Electronics 1297 09-01-2008 07:12 PM
