Old 10-30-2004, 08:27 AM   #1
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Default Charging Li-Poly
Hey guys,
I just bought a Li-Poly cell (7.4V 2450mah 10-12C discharge rate), and I was wondering if any one who also uses Li-poly cells could give me a base line charger set-up.
I use the GM Commander and it says it can charge Li-poly by adjusting the max-charge rate and the Max end voltage. Where I need help is to what do I set each to. I am not new to RC but new to Li-poly. It is for two cars. A 1/12TC and the new RC18t when it comes out.
thanks in advance.
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 10-31-2004, 05:13 PM   #2
ttt
Old 10-31-2004, 10:36 PM   #3
AdrianM's Avatar
Unless your GM charger has a constant current/constant voltage mode I would not use it. If you use a LiPo pack on an appropriate charger it is very safe. If you don't you basically have a small firebomb...i'm not kidding!
If you are running LiPo in an RC car be sure you know what the max current your motor/gear ratio combo will pull. A sedan with a 19T motor will see 50 amp+ spikes if you bump a wall under power. You would need a 2s3p pack of 10C 2100Mah cells (7.40v 6300Mah) to safely handle that. FYI, that pack would run a car for ~10-12 minutes at a race pace
Adrian Martinez
Old 11-01-2004, 12:15 AM   #4
TCR
what would you guys think about using a GFX to charge a 3 cell li po pack if I can keep an eye on the voltage.
I know someone who charged this same pack with a quasar pro and pulled the pack off around 14 volts he hasn't had a problem yet. any opinions. I just hate the idea of having to buy a special lo po charger just for this one pack, I use it as a transmitter battery works awsome.
TCR is offline   Reply With Quote
Old 11-01-2004, 07:20 AM   #5
newracer's Avatar
Don't use a GFX either. If it is for a simple tx pack get a simple wall lipo charger they are like $25.
newracer is offline   Reply With Quote
Old 11-01-2004, 07:48 AM   #6
I am going to call Horizon today, they are the distributors and they do the repairs and should know exactly how to charge a Li-po cell. I got some good answers from some airplane guys how basically said that you should only charge at the mah rate (i.e. since my pack is 2450mah then it should be charged at 2.4amps) and I shouldn't let it go past 8.4V total cell voltage. Which I can do on my GM Commander so I belive that if Horizon confirms it then I will try it. The Gm Commander is made in Germany and they don't realy explain the way in there instructions unless you are a battery charging genius. SO I say try it outside in a box and if it don't explode then it is OK...J/K I am making sure through Horizon.
Thanks for the warnings though, it is always good to have guys who are honest enough to not let guys put themselfs in harms way.
It is very apprieciated.
thanks,
Stephen <><
Orion Advantage DC Computerized Charging System (NiCD, NiMH and Li-Poly) DaSilva R/C Items: For Sale/Trade 23 01-29-2008 08:02 PM
Li-poly for DX2.0 rafaelmm Radio and Electronics 1 11-21-2007 07:19 AM
Li Poly humpacks? oldskoolRCR Nitro Off-Road 4 06-21-2007 10:38 PM
Poly Butler Box Arahawak R/C Items: Wanted to Buy 0 04-22-2007 10:29 AM
New RC CCA in Singapore Poly Kido Seishirou Singapore R/C Racers 6 04-07-2007 08:21 AM
