WGT DUO3  13.5 iN BLINKY MODE >
Old 08-04-2011, 04:44 AM
Default WGT DUO3 13.5 iN BLINKY MODE
Plan to run in the IIC in WGT class with a 13.5 duo 3 in blinky looking for rollout and timing for the motor.
tellan is offline
Old 08-04-2011, 09:06 AM
Default test day
i tested on tuesday on a 100ft X 50FT carpet layout.
Rollout of 75mm and 2 notches of advance on motor.Cells used were CRC 6300 65c I was 3 secs a lap slower than using boosted 10.5 .now i dont know if thats good or bad as have nothing to compare too but felt very slow.
tellan is offline
Old 08-04-2011, 09:19 AM
Trader Rating: 19 (100%+)
what are your current temps? I run a 100 by 38 foot track every week with an 80mm rollout and my temps never go above 150. Hope this helps!
COLD AS ICE is offline
Old 08-04-2011, 10:29 AM
Default temps
motor was very cool came off at 33c after 6 minute run. Might try uping the timing and rollout next test session.
Need to ge this sorted for Vegas IIC but guess there will be some advice there if in trouble.
tellan is offline
Old 08-04-2011, 10:37 AM
I had accidentally turned off the timing boost in my WGT 13.5 and I was able to drive the track in WOT and almost won but came in second by 3 or 4 seconds. My roll out was 65mm.
AreCee is offline
Old 08-06-2011, 03:26 PM
303slowdown's Avatar
Trader Rating: 24 (100%+)
Run a 3.5 fdr with full timing in motor you should be happy with it
303slowdown is offline
Old 08-07-2011, 05:21 PM
That rollout sounds kinda low to me, i could be wrong, But it also sounds like you could gear up a good bit.
Old 08-07-2011, 05:43 PM
That rollout was good enough to get the track record for fast lap, most laps in a main and first place for the winter series. Mind you that it was worked out for a timing boosted ESC with turbo. If I was racing blinky the rollout would be about 75 - 80.
AreCee is offline
