Old 08-03-2011, 10:05 PM   #1
Calamari100's Avatar
Smile Tamiya M-Chassis Shock Length
Hello,
I've got a Tamiya M-04, and I've been shopping around for new shocks on RcMart, and they have a couple of on-road alu shock sets from Yeah Racing and 3Racing that are pretty affordable compared to the tamiya ones.
My question is: what length of shocks should I get? I'm seeing ones that are like 50mm, 55mm, 60mm that sort of thing.
Any help would be appreciated!
have a nice day!
_________________________________________
Tamiya M04, Tamiya TT-01, Tamiya FF-02
Calamari100 is offline   Reply With Quote
Old 08-03-2011, 10:06 PM   #2
Originally Posted by Calamari100 View Post
Hello,
have a nice day!
http://www.tamiyausa.com/product/ite...oduct-id=84118
Lost in RC limbo
inpuressa is offline   Reply With Quote
Old 08-04-2011, 01:55 AM   #3
I was thinking picking up some aftermarket ones though. Do you know how long those Tamiya shocks are in mm?
Old 08-04-2011, 06:04 AM   #4
wollow86's Avatar
Should be 50mm. It's measured from the centre of the top mounting hole to the centre of the ballcup/lower mounting hole at full extension. 3 racing or trf are the go, I'm not 100% happy with my yeah racing ones on my m05.
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 08-06-2011, 12:09 PM   #5
cool. thanks for the heads up! probably going to pick up the 3racing ones.
Old 08-06-2011, 04:44 PM   #6
caltek1's Avatar
Trader Rating: 36 (100%+)
50mm sees rather short. I run mine at 56 - 57mm in length. Standard configuration is 61mm which will just give more droop. With the shorter shock, you need to use the shorter TRF, 3Racing spring sets or the old Tamiya 53333 springs.
caltek1 is offline   Reply With Quote
Old 08-06-2011, 09:51 PM   #7
I thought the same, but then by default the droop on the M05 is dictated by the length of the insert under the shock's piston and I don't run much of that (droop).
The Sakura Zero shocks do LOOK SWEEEEEEEEEEET and yes, they're the same length (shock body) as the included shocks with the M05 Pro. I was thinking about getting one. HOWEVER, they need 5.8mm ball ends and Tamiya gives you 5mm ones, BUT, my caliper revealed they're 4.75mm!!! By right, those pink 3racing ball studs come at 4.8mm should fit. Unless they're not 4.8mm as advertised.
cheapskate.brok is offline   Reply With Quote
TAMIYA M-06 Thread RC MARKET Electric On-Road 2151 Today 12:05 PM
TAMIYA "M" CHASSIS Darth Vader Malaysian R/C Racers 804 08-14-2011 11:28 AM
Tamiya Mini Cooper Club SuperEk4 Singapore R/C Racers 1123 06-20-2009 09:49 AM
M-chassis discussion diha Singapore R/C Racers 51 09-19-2005 06:57 AM
