Like Tree6Likes
Old 11-28-2013, 07:49 PM   #121
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
Mike Odonnell please PM me
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 10-04-2015, 04:02 PM   #122
Is there any disadvantage to mounting the servo flat in this car? I've got mine mounted on the angled mounts at the moment, and I'm not happy with the steering arm angles. If I use the inner holes on the servo saver to improve the angles, there isn't very much steering lock.
Scott Tapsall
Queensland Radio Circuit Car Racing Association
Pine Rivers Model Powerboat Club
Scott_T is offline   Reply With Quote
Old 10-05-2015, 05:33 PM   #123
Angled servos where designed for use in pan cars to minimize bump steer. I run my servo flat in my TOP WGT Rebel. I find that the steering is a little more aggressive and if you make sure that your steering links are level with the chassis plate when viewing from the front of the car, then you do not get too much bump steer although you will get more than if the servo was angled. To get the steering links level you need to space the ball up on the steering blocks.
Rocket RC Speed Shop - USA Importer of Team Powers products
[email protected]
http://rocketrcspeedshop.webstorepowered.com/
Crashby is offline   Reply With Quote
Old 10-05-2015, 08:49 PM   #124
Thanks Crashby, I'll have a go at running mine level and shim the balls to suit.
Scott Tapsall
Old 12-31-2016, 12:56 PM   #125
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
Anybody converted their Rebel 10's to the new WGT-R class yet? Any issues with ride heights and shimming? I'm going to try it when I get my rubber tires next week.
Josh-n-ya is offline   Reply With Quote
Old 04-16-2017, 08:39 AM   #126
Does anyone still run these with any success against the newer Xrays, CRCs etc?
Johnny Carey likes this.
rich67 is offline   Reply With Quote
Old 04-16-2017, 08:41 AM   #127
Does anyone still run these on foams against the newer crop of wgt cars. How do you go and any tips, setups etc. Thanks.
Old 04-16-2017, 10:15 AM   #128
hanulec's Avatar
Trader Rating: 27 (100%+)
Car is nice.. but in our area everyone went to wgt-r and I couldn't handle going that slow
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 04-16-2017, 10:29 AM   #129
dawgmeat's Avatar
Between 10-15 racers run 17.5 foam pan car down here in FL on carpet. You'll see mostly CRC's but there area a couple of racers who run older cars "BMI Copperhead" like myself and very with them
rich67 likes this.
dawgmeat is offline   Reply With Quote
Old 04-17-2017, 12:54 AM   #130
Thanks, I used to run a BMI many years ago back in the UK on carpet. Here in Aus we run on asphalt on foams, 2s battery, 13.5 blinky mode. There are a few Xrays but I don't like to follow the crowd too much as it may as well be one make racing. Variety is the spice of life after all.
Old 04-19-2017, 06:38 PM   #131
odpurple's Avatar
The Rebel 10 should work great for that formula. It comes with provision to run a 2S stick longitudinally or 1S either way. Still very competitive!
Taz_S and rich67 like this.
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 05-04-2017, 09:01 AM   #132
I have a new Rebel 10 and I am having trouble getting the ride height down at the rear with new foams on, I don't like truing 5/6mm of good foams just to get to ride height. I am looking for around 5/6mm ride height with 60mm new foams. Will the bearing carriers A, part #PC-RMAS05 fit the Rebel 10 and will they raise the axle thus reducing ride height? Thanks
Old 05-04-2017, 07:18 PM   #133
odpurple's Avatar
A blocks will actually require the use of even smaller tires. Use the B blocks and turn them upside down, as we do on our rubber tire F1 cars
