Like Tree6Likes
Old 08-20-2011, 06:41 PM   #16
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Hey od, wouldn't the rear pod bind under side load with that setup?
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 08-20-2011, 10:59 PM   #17
odpurple's Avatar
Not sure what you think you see there, it's a standard link car configuration. No binding
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 08-20-2011, 11:19 PM   #18
rx7ttlm's Avatar
not the links in the pod, just the axle bearings binding under lateral load(mid corner loading)
Old 08-21-2011, 02:09 AM   #19
BrodieMan's Avatar
Originally Posted by Bull_Dog View Post
The car looks nice, but if it's been released for two months why are we just hearing about now? I know it's just EJ and Micheal over here in the US but come on don't you think it's time to hire someone to update your website.
Indeed. The Rebel isn't even under the "Products" listing, just a few pics on the main page.
T.O.P. chassis look pretty sweet, cool to see another new WGT car
Mark Richardson
Kawartha Radio Controlled Racers
Lakefield Hobby & Game. ExtremeRCforum
Schumacher Mi4cx CRC Gen-X 10 LE
BrodieMan is offline   Reply With Quote
Old 08-21-2011, 11:50 PM   #20
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
The Rebel 10 works well. I get the privilage of being beat by odpurple every weekend with it. (peppy)
Josh-n-ya is offline   Reply With Quote
Old 08-22-2011, 12:20 PM   #21
odpurple's Avatar
Ok, I'll play along What do you think would cause that?
Old 08-22-2011, 12:37 PM   #22
odpurple's Avatar
Well, you're both right. T.O.P. made an announcement last October about the Rebel 10 and 10SS and it took until this May to get the first kits out. Not a very good time of year to introduce a pan car in the USA. We posted that we had the WGT in stock when we received them, but were unable to run the car until just before the nats at Jackson (it is just the two of us and Corky, our gifted/challenged assistant). So here we are.
The website is being updated right now and we will have it up soon
Old 08-22-2011, 12:39 PM   #23
odpurple's Avatar
Just keep putting the back wheels on the front like I told you
Old 08-22-2011, 02:35 PM   #24
Default First Race With New TOP WGT
Ran the car for the first time yesterday. Car was perfect!! Did not have to make any adjustments!! Car had great corner speed and was supper easy to drive. Was on TQ pace in last qualifier only to hit a dot and got the car upside down. When it finally stopped sliding and turn marshal got me back rolling, I had lost my TQ pace. Qualified second and finished second due to battery issue. (Low voltage. New batteries ordered) Ran the car with the battery down the middle (aka CRC) and right up against the back of the steering servo placing more weight forward. To set the car up this way, you need to order two parts, two rear cross brace stand offs and two washers. Maybe OD can post the part numbers.
This is a very nice car!!!!!
Crashby is offline   Reply With Quote
Old 08-22-2011, 02:51 PM   #25
odpurple's Avatar
Thanks Crashby. The kit comes with parts for longitudinal battery placement but they are designed for 2s rather than 1s so the stand offs are taller than neccessary for 1s. To lower the supplied battery cross brace/hold-down just use the 18mm rear cross brace standoffs (PC-RCH015RD, you need two) and fine tune the height to fit your particular battery with .5mm spacers (AW-M050RD)
Old 08-28-2011, 04:24 AM   #26
Hugh Jazz's Avatar
Ran my rebel 10 today on a Nitro track after racing had finished. Car felt great and was easy to drive with Xceed medium front and rear. Had great corner speed as well as change of direction. Gave two friends a go and both were impressed. Was told to try black side spring and centre shock.
Dan Maher
Hugh Jazz is offline   Reply With Quote
Old 08-29-2011, 01:08 PM   #27
Default TOP Rebel 10 Set Up From TOP Gun Race
Track = Asphalt
Layout = long, flowing, smooth & fast
Traction = High
Rebel 10
Battery position = center like CRC GenX and all the way forward
Battery = Fantom 1s
Speed Control = Tekin/Ramped
Motor = Team Powers 13.5
Front Springs = kit/copper
Front Track = wide/200mm
Front Roll Spacer = 1.5mm
Lengthened Upper Control arms = 2.0mm
Toe = 0
Caster = Full/all shims in front
Front Tires = BSR purple stripe - 54mm
Front ride height = 3.5mm
Servo = KO 951
Servo mount = Flat
Center Shock oil = 35
Center Shock spring = kit
Side dampener tube = 5000
Side springs = black
Rear ride height 3.5
Rear pod droop = 1.0mm
Rear Track = 200 mm
Rear tire = BSR purple stripe 57mm
Roll out = 61mm
Car was noticeably faster than the rest of the field. TQ'd by 10 tenths over second qualifier. Car has great corner speed and was easy to drive. A1 sesults = started from pole and on third dot got car upside down and went to last place!! Finished 2nd. A2 result = Started from pole and won. A3 results = Started from pole and won.
This is a very good car. If you have any questions about the set up, just ask. To get the 2.0mm upper control arm length does require some longer screws.
Old 08-29-2011, 01:46 PM   #28
odpurple's Avatar
Track = Asphalt
Traction = High
Rebel 10
Battery = Fantom 1s
Toe = 0
Servo = KO 951
Servo mount = Flat
Rear Track = 200 mm
Roll out = 61mm
Thanks for posting the set up and congtratulations on winning the TOP Gun Race
Old 08-29-2011, 01:49 PM   #29
Trader Rating: 18 (100%+)
Track = Asphalt
Traction = High
Rebel 10
Battery = Fantom 1s
Toe = 0
Servo = KO 951
Servo mount = Flat
Rear Track = 200 mm
Roll out = 61mm
Congrats on the WIN Steve!!! That comeback drive in the A3 was quite a show!!!
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 08-29-2011, 01:56 PM   #30
odpurple's Avatar
Just wait until the pics of him with the helmet on hit the internet!
