M05 and tc3 spring set up >
Old 08-03-2011, 05:16 PM
Default M05 and tc3 spring set up
Hey im kinda new to racing im wondering what kind of spring set up people are useing on these two chassis i race on asphalt its not a 100 percent smooth some small little bumps also the track is not sprayed. what do you guys suggest i was thinking for the tc3 silver front blue in th back please let me know my tc3 i use in trans am 21.5 turn motor and hpi radial tires that are used in the vta racing
sczrface85 is offline
Old 08-03-2011, 05:21 PM
valk's Avatar
if you have tire additive you can probably still run blue front silver back with 30-40wt oil. just lay the shocks down, take off swaybars and put a shim under the rear arm mount in the rear end to give a little rear caster.
i have an ntc3 but i think the electric is different. does the car have track and wheel base adjustment?
valk is offline
Old 08-03-2011, 06:06 PM
i was running blue in the back of the car silver in the front and i dont think it has the adjustments
Old 08-03-2011, 06:32 PM
valk's Avatar
typically you want the front stiffer than the rear.
valk is offline
Old 08-03-2011, 06:48 PM
sorry my fault i have the blue in the front and silver in the back i was confused lol
