Need help finding cheap alternative powersupply >
Old 10-28-2004, 08:41 PM
Super Steve's Avatar
Default Need help finding cheap alternative powersupply
As most of you know, a good powersupply (one that can pump out 15amps or more) is fairly costly.
I see these computer powersupplies but they never put the actual continuous amp rating. They just say max wattage. (for example 500watt) Does it mea it can pump 500/12 amps @ 12 volts?
Please help, thanks
-Steven
Super Steve is offline
Old 10-28-2004, 08:51 PM
Neil's Avatar
Is That the peak wattage of that ps If you use ohms law a 500 watt ps would put out 41 amps at 12 volts (P/E). Maybe it could peak at that but not continous.
Neil is offline
Old 10-28-2004, 09:55 PM
http://www.radiodan.com/misc/samlex1223.htm
Here you go.
NismoSkyline17 is offline
Old 10-29-2004, 12:25 AM
Radio Shack sells the same supply as above. I think they are about $79.99 when you can find them.
Lee H is offline
Old 10-29-2004, 01:08 AM
Matt Howard's Avatar
www.promatchracing.com has the victor 12amp powersupplies for $39.99 These are nice little powersupplies and if I didn't have my duracomm I'd probably get one.
Matt Howard is offline
Old 10-29-2004, 02:08 AM
PC power supply suppliers print the max amp output for each voltage on the label. 200 watt power supply usually gives you about 8 amps on the 12 volt line. 15 amps on the 5 volt line. My 600 watt PC PS has 25 amps on the 12 volt line.
Keep in mind that PC PS give out highly regulated 12 volts on the 12 volt line, most standalone PS give you 14 volts "no load" even if they say 12v, then the voltage can fall down to 10 volts when you're using the PS, but that's mostly the cheaper power supplies, high quality one will keep the voltage steady. I've seen one with 18 volts "no load" and it ruined a charger. Also keep in mind that a lot of chargers tend to false peak the batteries if the voltage is too low.
andsetinn is offline
